Weatherstripping Question - NCRS Discussion Boards
  • Dan D.
    • November 5, 2008
    • 1323
    Me again,
    I am going to have to replace the door weatherstripping on my 57. Seeing how my car is a driver and never will be judged, I am thinking about using later year C1 weatherstripping. There are 3 versions used from 56-62. Apparently several attempts were made in order to improve the sealing (can you believe it)! They are 56-58, 59-60, and 61-62. Looks like all the stuff is in stock at CC. Just not cheap is all.
    Has anyone done this? Are there major differences in the car? I know the front post is different, but I should be able to drill/tap the holes okay. Not sure if the serrations on the 57 post will be a problem.
    There are more fasteners holding the strips in place, but again, I should be able to drill holes okay. Is the fiberglass the same?
    Just looking for some advice.
    As always, I appreciate any help.
    Dan
  • Gary C.
    Administrator
    • October 1, 1982
    • 17768
    Re: Weatherstripping Question
    Dan,
    Check with Corvette Rubber https://corvette-rubber.com/collections/c1-1953-1962 since you're not concerned with judging.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
