November/December Driveline now available online - NCRS Discussion Boards
  • John W.
    Administrator
    • November 1, 1974
    • 5089
    The latest Driveline is now online. You can access it from the menu above, click on Online Publications and then select the Driveline link.
    Find the parts you need before they are gone.
    Administrator
    www.ncrs.org
  • Harry S.
    • July 31, 2002
    • 5330
    Re: November/December Driveline now available online
    Driveline will not download, just hangs on a blank tab.
    • Mark F.
      • July 31, 1998
      • 1572
      Wow, only 13 corvettes for sale in this issue !
      I remember when there were 13 PAGES of more in years gone by
      thx,
      Mark
      • Vinnie P.
        Editor NCRS Restorer Magazine
        • May 31, 1990
        • 1573
        I did everything the same as I always do, can't figure it out...if anyone absolutely NEEDS TO DOWNLOAD A HARD COPY, send me an email, NOT a private message on this board.
        Vinnie
        • Mark F.
          • July 31, 1998
          • 1572
          Originally posted by Vinnie Peters (17535)
          I did everything the same as I always do, can't figure it out...if anyone absolutely NEEDS TO DOWNLOAD A HARD COPY, send me an email, NOT a private message on this board. Vinnie
          it worked on my end, Vinnie
          thx,
          Mark
          • Vinnie P.
            • May 31, 1990
            • 1573
            I just tried it in 3 different browsers, Chrome, Firefox and Brave...both with and without my VPN connected, none worked...I can't figure it out.
            • Leif A.
              • August 31, 1997
              • 3645
              Just opened it, as usual. I use Chrome as my, default, browser.
              Leif
              • Harry S.
                • July 31, 2002
                • 5330
                It's not the opening. At the bottom of the screen right side there is an arrow to download the entire document to your computer. That is what is failing.
                • Mark F.
                  • July 31, 1998
                  • 1572
                  Harry - didn't know that is what you were saying earier...
                  agreed. i can download the 1st page; or any single page after that; but not the entire document...
                  thx,
                  Mark
                  • John W.
                    Administrator
                    • November 1, 1974
                    • 5089
                    I am sorry, I can't duplicate the problem as it downloads fine for me. You do need to check the box to download the entire document and not just the first page.
                    Administrator
                    www.ncrs.org
                    • Dennis C.
                      • June 30, 2002
                      • 884
                      I just tried downloading the entire document. It opens a new blank tab and that is all it does. The Driveline never downloads. This was done in Chrome.
                      • John W.
                        Administrator
                        • November 1, 1974
                        • 5089
                        Dennis,
                        Check your downloads folder to see if it did download. When it downloads there is usually a small icon in the top right of your browser Chromes shows a down arrow with a line under it . The page would be blank since you downloaded it and your not viewing a page. In Edge it opened up with the Driveline in the browser with a link to save it to my computer.
                        Administrator
                        www.ncrs.org
                        • Owen L.
                          • September 30, 1991
                          • 882
                          It successfully downloaded the entire publication on my MacBook Air (Sequoia 15.0.1) using Firefox (131.0.3).
                          What device & operating system are you using?
                          • Dennis C.
                            • June 30, 2002
                            • 884
                            Dennis,
                            Hi John,
                            I did check and nothing downloaded. I tried several times, the screen just sits there with an empty new browser window.
                            • Jack M.
                              • March 1, 1991
                              • 1181
                              Dennis- I had similar issues, but finally got the download working.
                              The issue might be a CACHE problem within our browsers (remembering 'older' info/attempts).
                              Try the following to clear the CACHE from the DRIVELINE page... if it doesn't work, the process won't cause any harm:
                              1) Hold down the SHIFT key on your keyboard.
                              2) While that key is still depressed, use your mouse to click the REFRESH button (clearing the CACHE).
                              3) After the page fully RELOADS, try the DOWNLOAD process again.
                              (it won't hurt to REPEAT the process a couple times)
                              (an alternate method is holding down the SHIFT key, then tap the upper row F5 key - if available on your keyboard)
                              In case you are unfamiliar with the REFRESH button, look for the button noted below... different browsers may change locations:
