Early '63 installed upper A-arm ball joint rivet question - NCRS Discussion Boards
    • November 1, 1998
    • 145
    Does anyone know the outside diameter of the rivet and thickness of the rivet head after being installed? (As seen on the bottom of the A-arm) Wanting to match installed rivet as close as possible to the rivet showned in the attached picture or does it matter for judging? Picture is from an early '63. Have not found anything in the manual or board.
    DSC04941.JPGThanks for any help or thoughts on this...Jack
  • Joseph S.
    National Judging Chairman
    • March 1, 1985
    • 933
    Re: Early '63 installed upper A-arm ball joint rivet question
    The rivets supplied with the Ball Joints work just fine for judging.
      • November 1, 1998
      • 145
      Thank you Joseph that will save me some time & head scratching
