C4 AC Problem - NCRS Discussion Boards
C4 AC Problem
+ More Options
Posts
  • Pat M.
    • April 1, 2006
    • 1579
    C4 AC Problem
    The AC on my 96 seems to have suddenly stopped working. I put the system on "auto", selected the temperture, like I always do, and it blew air but it was not cold.
    I also noticed that the radiator cooling fans did not come on when the engine was getting hot, which they normally would with the AC engaged.
    If I read it correctly, the service manual says if there's an AC problem I should see a fault code on my display, but I don't see any.
    Thoughts? Thanks
  • Gary C.
    Administrator
    • October 1, 1982
    • 17771
    Re: C4 AC Problem
    Pat,
    IIRC, the driver's side fan should come on when A/C is on. If the left fan doesn't come on, swap the fan relays. Fan relays are on the driver's side of the upper radiator shroud housing.
    If the fan comes on after swapping the relays. Then I'd replace both relays.
    Cooling fans are designed to come on at 225 degrees engine temp.
    Good luck.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Pat M.
      • April 1, 2006
      • 1579
      Re: C4 AC Problem
      Thank you Gary, I'll take a look at that.
      • Pat M.
        • April 1, 2006
        • 1579
        Re: C4 AC Problem
        Thank you Dave for your response.
        I did as you suggested and after holding down the fan arrows it did show "- 00". But when I released them and pushed and released the fan icon it showed "00".
        I don't see a flashing LED, and the temperature in my garage was just below the outside temperature at that time (mid to upper 70s in garage, lower 80s outside).
        I will test the charge.
        Thanks for your help
        • Pat M.
          • April 1, 2006
          • 1579
          Re: C4 AC Problem
          Thanks Dave, will do.
          • Pat M.
            • April 1, 2006
            • 1579
            Re: C4 AC Problem
            Thanks again Dave, I appreciate it
            • Pat M.
              • April 1, 2006
              • 1579
              Re: C4 AC Problem
              Follow up: It was simply low on freon. Despite the fact that the display did not show that fault code, it was low and when brought up to specs AC works fine, pressure is holding, and cooling fans are functioning as they should. Thank all of you for your help.
