Mid-year rear ride height - NCRS Discussion Boards
  • Leif A.
    • August 31, 1997
    • 3629
    Re: Mid-year rear ride height
    Peter,
    Zip will have the correct components needed.
    https://www.zip-corvette.com/63-82-rear-spring-outer-mount-bolt-w-correct-nut.html
    The upper spring cup is what is missing in your picture, as well. Who did this suspension refurbishment?
    This is the setup you're wanting to attain...NOTE: orientation of the large washers (rounded edges against the rubber bushing).
    Leif
    • Robert B.
      • March 1, 1992
      • 265
      yikes, nowadays you gotta do your homework before having any work performed.
      get a corvette supplier catalog or use the web sites when possible.
      • Gary B.
        • February 1, 1997
        • 7023
        #18
        Peter, the stock bolt will likely be too short.
        The cup is there....
        [ATTACH=CONFIG]123779[/ATTACH]
        • James W.
          • December 1, 1990
          • 2655
          #19
          Pete,
          I have a brand new in the box pair of correct length rear spring bolts, nuts, and the heavy flat washers and a few extra spring cups. Email me or PM me with your shipping address and their yours. I bought a second pair by mistake when restoring my '65.
          James
          • Mark E.
            • April 1, 1993
            • 4542
            #20
            A quick visual check for proper rear ride height: when the car is sitting within factory specs, the half shafts are parallel to the ground (this minimizes u-joint wear). Your half shaft is canted downward significantly ==> ride height too high.
            A second visual check: the spring bolt should not extend below the wheel. Compare Leif's car to yours. "Mechanics" sometimes try to compensate for a wrong spring rate or arch by using longer spring bolts. You can imagine the seat pucker factor during a blowout when a low hanging spring bolt digs into the ground.
            In your case, a longer spring bolt was installed in an attempt to compensate for the wrong spring (and/or other geometry problems), yet the car still sits too high.
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
            • Richard M.
              Super Moderator
              • August 31, 1988
              • 11323
              #21
              Ahhh, correct. I missed that top one.
              • Mark E.
                • April 1, 1993
                • 4542
                #22
                Originally posted by Gary Beaupre (28818)
                Rich,
                I’d bet someone bought the +1” spring, or bought an Eaton spring before they offered three versions and the spring wound up making the car too high. Leading to the purchase of the aftermarket, longer end bolts. Switching to the factory bolts may not return the car to the factory ride height. A different rear spring may be needed.
                Gary
                I'd bet you're right Gary. Using the same spring with shorter, factory bolts will raise the car even more.
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
                • James W.
                  • December 1, 1990
                  • 2655
                  #23
                  Peter,
                  I also have an original, rebuilt/restored rear spring if you find out that is what the problem is.
                  James
                  • John F.
                    • March 23, 2008
                    • 2409
                    #24
                    Here ie my 64.
                    • Gary B.
                      • February 1, 1997
                      • 7023
                      #25
                      Originally posted by John Ftacek (48800)
                      Here ie my 64.
