1963 1964 Cooling fan blade information/identification - NCRS Discussion Boards
  • David R.
    • February 1, 1990
    • 71
    Somewhere in its past, a previous owner chrome plated many of the under-hood parts on my car. I've found plenty of incorrect parts from other year cars as well.
    I am looking for information to identify the correct cooling fan for my 1964 non-AC car. The judging manual describes 3770529 as the correct fan for 63-64. Was that part number stamped or inked anywhere on the original part? What ink marks/stamps would be correct for this part?
    I have what looks to be a GM part that has been chrome plated it has no part numbers anywhere on the part. I am looking for someone who can tell if if this is a correct part. If it turns out to be the correct 3770529 fan, I'll have it de-plated and paint it gloss black.
    Thanks in Advance,
    Dave
  • Don H.
    Moderator
    • June 16, 2009
    • 2283
    Re: 1963 1964 Cooling fan blade information/identification
    Dave
    the 63,64, 65 small block no-AC fan looks like yours. It should measure from tip to tip 17 1/8". And should measure 1 3/4" from the table up to middle of blade edge. Your blades should measure 4" x 5 2/3" . The rivets could be mushrooms like yours or flat buttons. There were no part nos. imprinted and no ink stamps. The H is stamped in front, not visible behind the fan clutch when installed, as yours has. I say strip it, paint it black, and install.
    • David R.
      • February 1, 1990
      • 71
      Thanks Don,
      I need to make a trip to the plater to get other parts de-chromed. I'll add this fan to the batch. I appreciate your prompt reply and your expertise.
      Dave
