Right turn signal - NCRS Discussion Boards
Right turn signal
  • Bill M.
    • 1328
    Right turn signal
    I replaced the headlight harness and front turn signals on my 65 coupe after painting the car. My right front signal will not flash. I can hear the flasher ticking the rear right blinks. The parking light works. I tried a ne bulb and hooking the old light assembly up and still no blink. I took the telescopic steering assembly apart sprays all with contact cleaner. I pulle the harness off the firewall and still no blink. Any ideas ? Thanks. Bill
    • 6956
    Re: Right turn signal
    Bill, have you checked for power at the Front turn lamp wire, I believe it’s a dark blue wire,( I don’t have a diagram for 65) ? The power to the dark blue wire is feed through the directional switch viva the flasher wire. You can go under dash at steering column and use a test light or volt meter to check at connector. That will tell you if there is a problem with switch.(which are known to be a problem).
    • Stephen L.
      • May 31, 1984
      • 3162
      Do you have 4 way flashers? Do they work? If not I'd suspect the turn signal switch...........
      • Bill M.
        • 1328
        Ed thanks I acctually have no power at the firewall junction box I will go to that connector on Saturday.
        • Bill M.
          • 1328
          Steve the 4 ways work.
          • Stephen L.
            • May 31, 1984
            • 3162
            If the 4 way flashers work then the wiring is proven to be ok, as the 4 ways use the same wiring to the lights as the turn signal circuitry. This leads me back to the turn signal switch in the steering column having a bad/broken contact........
            Attached is the schematic by Jerry Fucillo/ Dave Zuberer showing the wiring for a 67. I assume the 65 is similiar.
            • Bill M.
              • 1328
              Thanks Steve I will look into the signal switch.
              • Bill M.
                • 1328
                Steve looks like I need the turn signal switch. I will take care of that over the winter. Going to clean up the engine compartment as well. Thanks all
