While car was on a lift at the shop, discovered the harmonic balancer appears to be rubbing the timing chain cover. The harmonic balancer is the correct original. Motor was rebuilt in the late '80's with probably less than 500 miles on it since then. As far as I know, the harmonic balancer has never been removed since. Any thoughts how that can be making contact other than it was "hammered" in at the rebuild or was done at one of the previous shop visits?
Thanks in Advance,
Fred
Thanks in Advance,
Fred
