Hood Hinge Restoration - NCRS Discussion Boards
  • Keith M.
    • January 17, 2021
    • 695
    Is it possible? Are there any known/recommended places/folks who do this. Attached is pic of one of mine. some holes are elongated and the piece (special washer?) that keeps the two parts in tension is very loose.
    late Oct 1969 L46 350/350, M21 4spd, 3.70 posi convertible --As with life, restoration is a journey, not a destination. Though restored cars provide both journeys AND destinations!
    • 11692
    Re: Hood Hinge Restoration
    Given that a set of new Made-in-USA reproductions with shims and bolts is $80 or less, I doubt that there is any value in restoring these.
    You might be able to disassemble the pivot pin, have them replated, and then reassemble with parts stolen from the reproductions if you REALLY wanted the original pieces on the car.
    • Michael B.
      • February 1, 1985
      • 76
      My set looked pretty much the same as the OP. Purchased repro. They look correct and spectacular. 👍
      • Lawrence S.
        • April 1, 1993
        • 804
        I went with reproduction on my 67 National TF car.
