1963 AM Radio Repair - NCRS Discussion Boards
  • Frederick H.
    • August 31, 1983
    • 431
    Several prevous threads on this for sources but Jerry Sudeck (spelling?) has retired from Electro-Design/Turnswitch and their site says they no longer repair radios; Gary Tayman @ Tayman Electronics said he no longer repairs, just does conversions (to FM, Bluetooth, etc.). Does anyone have other sources that they have had good experience with? I can check with DMS or Clocks by Roger but thought I would reach out first.
    Thanks in Advance,
    Fred
  • Owen L.
    • September 30, 1991
    • 868
    Re: 1963 AM Radio Repair
    Robert repaired, cleaned, and tuned my '72 radio:
    • Gary C.
      Administrator
      • October 1, 1982
      • 17659
      check with https://www.doctordons.com/ he does excellent work
      Gary
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Frederick H.
        • August 31, 1983
        • 431
        Excellent - thank you!
        • Frederick H.
          • August 31, 1983
          • 431
          Has anyone heard if the conversion to AM/FM is counted off in judging? Gary Tayman says you can't tell by looking at the front of the radio and when I have judged in the distant past, I never checked behind the radio (if the wiring is even different). If I go to the FM conversion, I may have to get an updated speaker which I do not want to hassle with.
          Fred
          • Gary C.
            Administrator
            • October 1, 1982
            • 17659
            Fred,
            FYI - AM/FM radios were delivered in 1963 Corvettes made after Feb 1st or thereabouts.
            Gary
            NCRS Texas Chapter
            • Frederick H.
              • August 31, 1983
              • 431
              While the JM says AM-only up until "around VIN 12,000" (I have a late March car that is under VIN 12,000), I agree that there is that gray area timeline that one cannot definitely say exactly when they switched over. Having a March car is a pain - lots of changes around VIN's in the 11,000 range. Since it originally came with an AM, that's probably what I will stick with. Lots of talk shows .
              Fred
              • Mike L.
                • January 1, 1986
                • 312
                Earliest know AM/FM radio in 1963 documented car is Vin # 9403. Silver Z06
                • Harry S.
                  • July 31, 2002
                  • 5295
                  Radio ID tag off the 9403 car.
                  • Dave S.
                    • August 31, 1992
                    • 2924
                    Originally posted by Gary Chesnut (5895)
                    Fred,
                    Gary
                    Correct. It was found in the silver Z06. VIN in the 9400 range if I recall correctly. Found factory paperwork to confirm.
                    • Gary C.
                      Administrator
                      • October 1, 1982
                      • 17659
                      per the Chevrolet "Friday Night" letter #5 RPO U69 AM/FM radio is available to order mid Febuary
                      NCRS Texas Chapter
                      • Frederick H.
                        • August 31, 1983
                        • 431
                        Wow - thanks for the documentation (Gary, how did you find the letter?) and photos. If I can find an original AM/FM, does anyone know if it will require a different speaker?
                        Fred
                        • Harry S.
                          • July 31, 2002
                          • 5295
                          Fred
                          Fred, if you have the 1963 AIM, there are a few items to check:
                          1. Compare the speaker part number in the AM section to the AM/FM section
                          2. Compare the antenna cable part numbers, think the AM and the AM/FM were different
                          3. Compare the hardware in the rear for the antenna mount, brackets, ground straps, etc
                          4. I know the AM cars had a steel fender support and the AM/FM radios had an aluminum fender support. The steel support left a rust stain on the fiberglass and the aluminum support left a dark shadow on the fiberglass.
                          • Frederick H.
                            • August 31, 1983
                            • 431
                            You are correct - I forgot about the antenna. For no more than I am going to drive it, and to keep it as it came from factory, I'm sticking with the AM. Thanks for the reminder Harry.
                            • Gerald C.
                              • June 30, 1987
                              • 1283
                              Radio ID Tag #86FMA-2020 off of my April 1963 Car
