67 brake master cylinder ID - NCRS Discussion Boards
  • Jeffrey S.
    • April 1, 2004
    • 133
    I just replaced my master cylinder in my 66 / it had the 67 type master cylinder with the dual pistons . It was giving my poor braking so I replaced it and all is currently great / what I would like to know is what the 2 letter code on the master I took out means the code was CZ . Any info would be appreciated . thanks Jeff
  • Leif A.
    • August 31, 1997
    • 3658
    Re: 67 brake master cylinder ID
    Jeff,
    A "correct" '67 master cylinder for standard and power brakes would have "DC" stamped into the forward machined area. Have no idea what the "CZ" is on yours.
    Leif
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11367
      I believe it was for a C3. It rang a bell so I searched.
      Maybe "ZC" ? CLICK HERE
      Rich
      • Jeffrey S.
        • April 1, 2004
        • 133
        Thanks for your replies I knew what it should be I just want to know what I had . Thanks again Jeff
          • 43290
          Jeffrey------
          As I mentioned in a previous post, the embossed broadcast code ("CZ" in your case) may be irrelevant if the master cylinder has been through a commercial rebuilding operation. What's more important for you is the casting number. The 1" bore 1967+ master cylinder carried casting number 5455509. That's the one you want to use to ensure braking characteristics similar to your original master cylinder. All 1966 Corvettes, standard or power brake, were equipped with a 1" bore master cylinder.
          There is another master cylinder which is externally the same as 5455509 but with a 1-1/8" bore. That master cylinder carries a casting number of 5460346. You could use it but the braking characteristics will be somewhat different than your original 1" master cylinder. It might not be very noticeable, though.
          • Jeffrey S.
            • April 1, 2004
            • 133
            Thanks for the reply / I appreciate your input . Jeff
