1954 exhaust manifold heat riser - NCRS Discussion Boards
  • Tim M.
    Infrequent User
    • July 14, 2012
    • 29
    Will a 1954 dual exhaust manifold work if it is missing the heat riser valve? (The holes for the heat riser have also been welded up). I know 1954's are supposed to have a plate blocking heat from the exhaust manifold going to the intake, But is the heat riser still serve some purpose. Will the car run ok without the heat riser?
  • Chris S.
    • January 1, 2000
    • 1068
    Re: 1954 exhaust manifold heat riser
    It will run fine
    Make sure to have the block off plate installed....
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
