66 E-brake cable clip question /problem - NCRS Discussion Boards
  • Robert P.
    • October 19, 2019
    • 321
    I have an early 66 roadster that has the early style clips for the cables, the clips i am using from gm are the service ones#516213 and they end up falling out on the frame bracket end of the cable , it seems the cable moves (new gm nos cable )from being so stiff. I dont believe this would happen with the later 66 micky mouse style clips . Anyone have an issue with this or a solution to the problem
    thanks Bob
  • Mike M.
    • December 20, 2013
    • 33
    Re: 66 E-brake cable clip question /problem
    Bob,
    I too have troubles with the d/s u-clip dropping off - p/s is fine. I noticed yesterday that I've lost my third clip. I don't have a solution yet and am hoping someone replies and helps us both.
    Mike
      • 11692
      Have you tried pinching the ends of the clip closer together, even after the clip is installed?
      I can see how the Mickey Mouse clips would be tighter, but narrowing the ends of the U-clip might help.
      • Robert P.
        • October 19, 2019
        • 321
        I have not tried that yet but is next on my list of things to try
        thanks Bob Peckham
        • James W.
          • December 1, 1990
          • 2673
          In the '65 AIM, there is a note stating that once the clip is installed, to rotate it so it faces down. Is there a note in the '66 Aim stating the same? I've done this and haven't had any issues with the clips coming off.
            • 11692
            I assume that means open end down, closed end up?
            • Robert P.
              • October 19, 2019
              • 321
              I just checked my AIM and you are correct, i will install the new ones by the book and see what happens
              thank you very much for the info
              Bob Peckham
              • James W.
                • December 1, 1990
                • 2673
                Yes, open end down and closed end up.
                • Mike M.
                  • December 20, 2013
                  • 33
                  Thanks James and Patrick.
                  Bob, please let us know if these suggestions work for you.
