SEMs Interior dye_right color_ do's & don'ts - NCRS Discussion Boards
  • David M.
    • September 30, 2004
    • 535
    Just had the seats reupholstered. The rest of the interior needs to be re-dyed to match. The door panels, dash & console are in good shape just the wrong color to match the 411 metallic blue, bright blue, not 100% clear on the color name. PO changed the interior to one of the other 68 Blues.
    Interested in hearing about the success or failure of the process.
    Any do's/don'ts, using the plastic prep, adhesion promoter, and top coat??
    The windshield is staying in so I imagine the dash will be fun.
    Has anyone re-dyed a 411 code interior on a 68? What color code did you use? I can't seem to find that color. I'm going call SEMs later today. Maybe give Al Knoch a call too.
    TX
    Dave
    • 11698
    Re: SEMs Interior dye_right color_ do's & don'ts
    TX
    Dave
    Don't even think of doing it without pulling everything out.
    The upper dash is not difficult to remove if you first remove the windshield header and then A-pillar trim.
    As with any painting job, stick with one brand. And, preparation is the key.
    I used the paints from Corvette America / Top Flight on Dad's 72 last year.
    There are different products for hard vs soft plastics (vinyl), and I did use the recommended prep products with good results.
    Having the parts lay on some saw horses or similar for painting them will work to your advantage.
    • David M.
      • 535
      Good info. TX.
      What color did you use?
        • 11698
        My parts were easy. It's a black interior.
        • David M.
          • 535
          Easier indeed.
          • Frederick H.
            • August 31, 1983
            • 486
            I tried red dye for my '63 door panels a few years back and it had a flat finish and was a lighter red (almost dark pink) so I am going to try a different source for my next attempt.
            Fred
            • David M.
              • 535
              From what I'm to understand, of you have a good paint house they can mix colors for a better match. Ill bet Al Knoch will have some good info?
              • Frederick H.
                • August 31, 1983
                • 486
                The interior guy that is going to fix some of the mistakes of a local Corvette shop actually referred me (today) to a guy who will take a look at painting them to match. All of the trim and radio panels are painted to meet the judging guidelines.
                Thanks David!
