65 Turn Signal Flasher - Tung Sol 323 - NCRS Discussion Boards
  • Charles P.
    • November 1, 2021
    • 38
    Hi, I am trying to correct my 65 car's turn signal flasher back to OEM. It has a 552 aftermarket flasher can and it works fine. I found a couple old Tung Sol 323 flasher cans. When I replace the aftermarket unit with the Tung Sol 323, the turn signals just stay on/lite but do not flash. It is possible that both 323 turn signal flashers are bad. Is there any other possible cause that I may be overlooking for this behavior (given it is such a simple circuit design)?
  • Leif A.
    • August 31, 1997
    • 3653
    Re: 65 Turn Signal Flasher - Tung Sol 323
    Charles,
    Are you using stock type 1157 incandescent bulbs?
    Leif
    • Joseph S.
      National Judging Chairman
      • March 1, 1985
      • 930
      If you use the 323 flasher, you must also use 1034 bulbs in the front parking and tail lights. Try that and see if your flasher will work.
      • Dave S.
        • August 31, 1992
        • 2930
        The flasher changes with back up lights. You may need a different flasher.
        • Charles P.
          • November 1, 2021
          • 38
          Originally posted by Leif Anderson (29632)
          Charles,
          Thanks for your post. They are incandescent bulbs probably form the early 80's when the car was restored. I will check the bulbs. Thanks...
          • Charles P.
            • November 1, 2021
            • 38
            Thanks Dave, you are correct. I believe I need the 224 not the 323. I have the Oct 64 Parts Catalog and it is there a few lines down from the 323 as a "2 bulb" flasher. The old eyes just didn't see it. I have one on the way and will try it next week. Have a great weekend everyone!
