Master cylinder with rust and porosity - NCRS Discussion Boards
  • Justin S.
    • July 3, 2013
    • 305
    1970. Is it worth soaking this in a caustic bath to clean. If so, is there anything else I can do to rebuild it while it's removed? AIM lists the part number as 5458831. If rebuilding isn't an option does this number still apply?
    My brake system is open with new lines and none of this was introduced to it.
    • 11692
    Re: Master cylinder with rust and porosity
    I'd be buying a reproduction with the correct date stamp on it.
    The inner bore looks bad even through those small holes.
    • Justin S.
      • July 3, 2013
      • 305
      Thanks, Patrick. I'll be looking for a reproduction.
      • John P.
        • January 1, 2006
        • 163
        Hello Justin, contact CSSB Inc. ( Corvette Stainless Steel Brakes Inc.) at 800-262-9595. They make new exact reproduction master cylinders with correct part and date code stampings. Go on their website and view all their products. I have installed many of their master cylinders, brake calipers, and brake components over the years and have absolutely no problems. They offer excellent technical advice if needed and have fast delivery of their products. John
          • 43278
          Justin------
          Please report the CASTING number which is on the side of the master cylinder. It should be 5460346. From what I can see of this master cylinder in your photo, I'm not even sure this is an original GM master cylinder.
          • Leonard M.
            • September 7, 2009
            • 236
            What Joe said.
            • Justin S.
              • July 3, 2013
              • 305
              Joe,
              There's not GM casting number on the master cylinder
              I'll be taking Patrick and John's advice.
              • Mark F.
                • July 31, 1998
                • 1598
                Joe, There's not GM casting number on the master cylinder I'll be taking Patrick and John's advice.
                Justin,
                No casting number on this part means it's not GM.
                thx,
                Mark
                  • 43278
                  Originally posted by Mark Francis (30800)
                  Justin,
                  Mark and Justin-----
                  ...and, thus, it's absolutely not worth rebuilding even if it could be rebuilt.
                  • Justin S.
                    • July 3, 2013
                    • 305
                    Will these pits in the booster cause a loss of vacuum?
