body bolts torque - NCRS Discussion Boards
body bolts torque
  • Mel S.
    • August 31, 1992
    • 264
    body bolts torque
    I need the torques specs for all of the body bolts for a 66 convt.
    Mel
  • Gary B.
    • February 1, 1997
    • 7046
    Re: body bolts torque
    Mel,
    Have you checked your AIM sheets UPS 1 ASM G2 & G3, and UPC 11-13 A5?
    Gary
    • Mel S.
      • August 31, 1992
      • 264
      Yes but they give 2 different spec's. I just wanted to double check
      Mel
      • Gary B.
        • February 1, 1997
        • 7046
        I think all the body mounts with cushions are consistent at 40-50 ft-lbs. No?
        The one at the radiator core support is lower, but it has no rubber cushion. Just use what the AIM says to use.
        Gaty
        • Mel S.
          • August 31, 1992
          • 264
          Thank You for the responce
          Mel
