Original OLA Fuel Tank - NCRS Discussion Boards
  • Jim W.
    • April 1, 2006
    • 228
    How can I tell if my tank is original or Quanta replacement in my Nov 63 built 64? The OLA logo is sideways to the car and the sending unit says "AC Made IN USA with a large letter S on the left and I to right side. The anti vibration straps are GM logo cork.
    Thanks Jim
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: Original OLA Fule Tank
    These are photos of my 67 original tank. The anti rattle strips are original. They are about 3/32 thick. They appear to be a "tar" impregnated felt material with a pattern of "needle" punctures........... There are 2 widths: 1.5 in and 2 in.
    Last edited by Stephen L.; March 31, 2024, 07:25 PM. Reason: added photo of sender
    • Jim W.
      • April 1, 2006
      • 228
      Looks like mine except for the tar felt strips. Maybe my tank is original but someone changed to cork strips at some time. The tank does look old and I have no reason to believe it was replace based on the cars history.
      • Stephen L.
        • May 31, 1984
        • 3158
        Gm could have changed the strip material. Mine is a 67.
        • Mike M.
          • May 31, 1974
          • 8389
          all c-2's I've restored had an asphalt impregmated straps. never seen cork. mike
          • James W.
            • December 1, 1990
            • 2657
            Here's the original from my '65. Before and after clean up.
            James
            • Jim W.
              • April 1, 2006
              • 228
              Removed tank today. The cork strips are not GM, rather standard blue stripe rolled cork gasket material cut in strips and contact cemented. There also is what appears a 2"x2" black plastic patch under the front strip. I think what happened; there was a pinhole leak that got repaired and they trashed the felt and replaced with cork.
              Thanks for all the pics
              Jim
              • Jim W.
                • April 1, 2006
                • 228
                Fule Tank 2.jpgFule Tank.jpgHere are two pics. The first one shows an ink stamp. Anyone know what the numbers represent?
                • Stephen L.
                  • May 31, 1984
                  • 3158
                  Those printed numbers on the sheet metal were discussed about a month ago on this board. Probably ID stuff for the sheet metal manufacturer.
                  • Don H.
                    Moderator
                    • June 16, 2009
                    • 2262
                    Was this the thread?
                    https://www.forums.ncrs.org/showthre...ight=fuel+tank
                    • Stephen L.
                      • May 31, 1984
                      • 3158
                      Re: Original OLA Fuel Tank
                      Yes that was the thread
                      • Jim W.
                        • April 1, 2006
                        • 228
                        James, what did you use to clean and shine up your tank. I need to do the same.
                        • James W.
                          • December 1, 1990
                          • 2657
                          • Jim W.
                            • April 1, 2006
                            • 228
                            James, thanks for the through description. Sounds like a good plan. I love Evap-O-Rust (use it for everything). Just starting a total body off restore even though I bought this car 20 years ago; so I have a long haul and will posting lots of questions.Body Removal.jpg
