Factory installed PF46 oil filter - NCRS Discussion Boards
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11367
    #31
    Re: Factory installed PF46 oil filter
    Joe, Your explanation and details were a superb example of exactly the kind of information we were hoping for. Thanks very much for your help. I love learning from you.
    Rich
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11367
      #32
      Harry------
      According to my information, the PF-46 is still available under GM #12731172. However, I suppose it is possible that it has now very recently been replaced by the PF-46E, GM #12737094. Both of these filters had been available for quite some time. The only difference between the PF-46 and PF-46 E is that the PF-46 has the base plate directly tapped for the oil filter connector fitting while the PF-46E has a threaded insert in the base plate for the fitting.
      Supposedly, the threaded insert is used to make the filter more recyclable. However, I fail to understand how it changes recycling potential from the direct tapping design. This same "threaded insert" design is being phased into a lot of other AC filter part numbers. Personally, I do not like it and avoid it, if possible, when I buy oil filters. To me, it just represents another possible failure point which is eliminated with the direct tapping design.
      I didn't know the PF 46E had that threaded insert. I'd be curious to see some closeup images of it, if someone has one handy.
      Rich...... Edit. I found one online. Hard to see the Bypass Valve though. Is there one?
      PF46E
      PF46 w/Bypass
      Last edited by Richard M.; March 25, 2024, 04:23 PM. Reason: Removed typo "blueberries". sMart(dUmb)phone got me again...lol.
        • 43289
        #33
        blueberries.
        PF46E
        [ATTACH=CONFIG]121560[/ATTACH]
        PF46 w/Bypass
        [ATTACH=CONFIG]121561[/ATTACH]
        Rich------
        PF-46 or PF-46E has no bypass valve. Either do have an anti-drainback valve, though. PF-48 or PF-48E do have both valves
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11367
          #34
          Joe, Thanks for clearing that up. Sorry I never replied back to your post.
          For future reference, it's a drainback vs bypass valve.
          Rich
