Delco Freedom Battery Series - 1978-80 & Their CCAs - NCRS Discussion Boards
  • Tom R.
    • June 30, 1993
    • 4100
    In studying battery use in 78/79 for the revision of the TIMJG, I've concluded that two heavy-duty batteries were called out and their usage extended into 1980. Then the Freedom Battery IIs were introduced. I used a Delco Electronics Products catalog dated Sep 79 that helped with cold cranking amp assignments.
    I also referred back to buildsheets to see what model was called out. Prior to 78, buildsheets called out the battery model 87-5 or even earlier the R series. But in 78, a three-digit code is used, referenced no where but on the AIM. Data processing typically use the last three-digits of the VIN as the code on a buildsheet.
    Well, interesting enough, until I figured code usage on the buildsheet, did I understand the three-digit code on 79 battereries...the label listed the three-digit code. At the bottom of the label is listed a recommended replacement battery. Back to the two UA1 heavy-duty batteries, both of which saw usage in both years. The attached two-page PDF shows the progress for the revision listing both 78 model numbers, and their companion batteries in 79 with the three-digit code. Also shown is cranking amps. I have access two original 79 batteries; their owners contributors to the topic. Additional owners of original 78/79 batteries are welcomed to join in.
    What I am seeking is a source that can verify the CCA for a 527 battery, whose replacement is the 89-60. The 89-60 is listed in the Delco Elec Products catalog with 505 CCA. Note I skipped battery size that seemed critical in battery discussion threads a decade ago. I figured that standard battery deductions kept judges out of the battery compartment with their rulers! LOL
    1978-79 Delco Battery_21Feb24.pdf
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
  • Ralph S.
    • February 1, 1985
    • 935
    Re: Delco Freedom Battery Series - 1978-80 & Their CCAs
    • Ralph S.
      • February 1, 1985
      • 935
      Log into Facebook to start sharing and connecting with your friends, family, and people you know.
      • Tom R.
        • June 30, 1993
        • 4100
        Still worthy of standard deduct!
        Tom Russo
        78 Pace Car L82 M21
        00 MY/TR/Conv
