65 Hood Release Handle - set screw - NCRS Discussion Boards
  • Stephen B.
    • April 1, 1988
    • 879
    I'm going to assume that this ugly screw is not original. What there a set screw instead? Please advise, and thank you in advance.
  • Joe R.
    • July 31, 1976
    • 4552
    Re: 65 Hood Release Handle - set screw
    This is gonna be interesting! Answer is there was NO set screw. The handle was pressed on the shaft. I"m sure that repo handles had some kind of screw! Lets just see what the repo"s can come up with!
    JR
    • Stephen B.
      • April 1, 1988
      • 879
      This car was not driving since 1983; therefore, there was not repo's then. It must have been a shade tree fix. lol. Maybe JB weld will keep it on there, instead of the screw.
      • Dan B.
        • July 13, 2011
        • 545
        I've seen many with some type of screw to hold the handle on after it pulled off. My method to repair is to drill, tap and install a shallow set screw and then fill both outer ends with JB weld and repaint the handle if its still good. Makes a permanent invisible repair that appears original.
        • Stephen B.
          • April 1, 1988
          • 879
          Great idea. Thank you.
          • Daniel J.
            • July 29, 2007
            • 158
            • Harry S.
              • July 31, 2002
              • 5342
              On my 63 the wire broke just above the handle. I ground it down even with the handle. Then drilled it out. I used the same gauge piano wire and used JB Weld to set it in place. I cut the wire too long on purpose. After I installed it in the car, I trimmed the wire to the proper length. It has been fine for the last 12 years.
