1969 350 Hp Valve Cover Restoration (Before & After) - NCRS Discussion Boards
  • Jeffrey S.
    • May 31, 1988
    • 1882
    Re: 1969 350 Hp Valve Cover Restoration (Before & After)
    I have been using this for years and it always maintains the exact temp I set, has no flame, and no fumes that I can detect. Simply plug in and plate when heater turns off. It will turn back on when needed.
    Jeff
    • Tom R.
      • June 30, 1993
      • 4099
      Kevin, Jeff & Patrick
      If its not too much trouble, post a picture of your setup, the Coleman's and the water heater probe. I look up Coleman's and there is a zillion options.
      Tom Russo
      78 SA NCRS 5 Star Bowtie
      78 Pace Car L82 M21
      00 MY/TR/Conv
      • Jeffrey S.
        • May 31, 1988
        • 1882
        #18
        Tom,
        I will most likely be in my shop over this weekend sometime and will get picture for you.
        Jeff
        • Jeffrey S.
          • May 31, 1988
          • 1882
          #19
          Here are 2 pictures of the set up I use. It's a little crude and well used but it works. I use a clamp to hold the element in the bath and a bungee cord to hold the thermostat on the side of the pail. I tried to rotate first photo but could n ot.
          Jeff
            • 11643
            #20
            I used mine today but didn't see the request until after then.
            It looks just like this, but a gold fuel tank as it's older.
            It works great.
            My stove uses white gas, not unleaded and not denatured alcohol.
            I suspect you could use a newer one that uses the canisters if you want, but the older white gas ones are easily available on Marketplace, etc.
            • Kevin S.
              • January 5, 2011
              • 255
              #21
              Hi Tom,
              I'm so sorry about the delay. Your request for pics ending up in my email junk folder and I did not see it until today (02/27/2024). Here is my Coleman stove and parkerizing setup that I use. It was my wife's idea to put all my stuff on this push cart, she is WAY smarter than me and better organized. Pics are taken indoors but I do all of my parkerizing outdoors. I also have a 6' plastic folding table that I sit adjacent to my stove where I put all my stuff while I am parkerizing.
              Stainless steel pots with vented glass lids and baskets from Walmart
              Cheap tongs to turn and move parts from Walmart
              Thin temperature probes from Walmart - I have three of them, one for each pot and one spare
              Chemical gloves from Harbour Freight
              Goggles from Lowes
              Parkerizing solutions from Palmetto Enterprise
              Push cart from Harbour Freight
              Coleman 2-burner Camp Stove I've had forever, don't recall where it came from. Camping World I think?
              I do use the Coleman all-purpose propane green screw-on bottles for my setup
              Kevin
              • Tom R.
                • June 30, 1993
                • 4099
                #22
                That's a serious setup! Must be production level. LOL I have the push cart.
                Thanks all for the photos...helps to get the right stuff from the start
                Tom Russo
                78 Pace Car L82 M21
                00 MY/TR/Conv
                • Kevin S.
                  • January 5, 2011
                  • 255
                  #23
                  Update on parkerizing:
                  I parkerized a few parts 2/29/2024 and wanted to add one more detail that I discovered by trial and error to clean my stainless steel pots, baskets, tongs, temperature probe tips. This stuff works absolutely great at removing the scale buildup left in the bottom of the pots after parkerizing and on the surface of other metal parts....
                  Rust-Oleum Rust Dissolver solution - got it from Ace Hardware.
                  Pour a small amount in bottom of scaled pot, sit maybe 3 minutes, wipe clean with shop towels. Pots inside look brand new again. Pour a little into shop towel and wipe off temperature probe and bottom of pots and my removable baskets.
                  Kevin
                    • 11643
                    #24
                    Kevin
                    Thanks for the tip.
                    I've just left the layer inside my pots that develops, and it doesn't seem to get any thicker or hinder the process.
                    Yes, I would like them clean but I don't mind simple either.
