63 Coupe Drivers Door Mirror Bracket - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5333
    I can't get access to the car right now.
    Anyone have measurements as to where to drill the holes in a coupe door to install the 63 short-base mirror bracket?
    Harry
  • Harry S.
    • July 31, 2002
    • 5333
    Re: 63 Coupe Drivers Door Mirror Bracket
    This is what I got of my 63 Coupe. Any comments. Thanks.
    The existing holes in the door skin are from a long base mirror. I need to mount the short base mirror mounting bracket on the inside.
      • 6950
      Harry, will the metal reinforcement for short base give you the correct hole location if you mount it? Or are you just trying to drill through the old plate?
      • Harry S.
        • July 31, 2002
        • 5333
        Ed, it's an NOS early 1963 door skin with pre-drilled holes for the long base mirror. I need to fill & drill for the short base inside mounting bracket.
          • 6950
          What if you buy the inside short base mounting plate. and use for a template?
          • Harry S.
            • July 31, 2002
            • 5333
            Ed, Thanks, I'll give you a call.
