M20 or M21 - NCRS Discussion Boards
M20 or M21
  • Leif A.
    • August 31, 1997
    • 3655
    Re: M20 or M21
    Originally posted by Gary Beaupre (28818)
    In Noland’s chart I don’t find L79, with 3.36 posi, and wide ratio, M21. But in the last chart that Jack posted, that combination is there. My ‘66 has that combination. Did that combination disappear for ‘67? Or is Nolan’s chart incorrect?
    Gary
    Gary,
    For both '66 and '67 model years when ordering the L79 option you could get the M20 wide ratio transmission with either the 3.36 open rear as standard equipment or 3.36 posi as an option. When ordering the L79 option with the M21 close ratio transmission, the 3.70 open diff was standard with the 3.70 posi available as an option. When the M20 was ordered you could, also, opt for a 3.55 open or posi rear. When the M21 was ordered you could opt for the 4.11 open or posi rear.
    You could not get the 3.36 or 3.55 gearing with the M21 nor could you get the 3.70 or 4.11 with the M20.
    Leif
    • Gary B.
      • February 1, 1997
      • 7078
      Re: M20 or M21
      Thanks for the explanation.
      Gary
        • 15706
        #18
        Re: M20 or M21
        Gary
        Wide ratio is M20, close ratio is M21.
        The WR (M-20) 4-speed with a 3.36 axle was likely the most common drivetrain for L-79 in '66 and '67. Download the information packages from the GM Heritage Web site. They have all the drivetrain charts and lots more.
        • Gary B.
          • February 1, 1997
          • 7078
          #19
          Re: M20 or M21
          Thanks Duke. I corrected my above post so as not to confuse future readers.
          Gary
          • Gary S.
            Super Moderator
            • February 1, 1984
            • 460
            #20
            Re: M20 or M21
            And my original drivetrain 67 coupe, made Sept 1966, with tank sheet (removed by me) shows 350/M20/3:36 posi.
            Avatar--My first ever vette, owned 3X since 1977, restored 1993-2024. Top Flight Award 9/14/24
            • Gary J.
              • April 1, 1980
              • 1246
              #21
              Re: M20 or M21
              • Gary S.
                Super Moderator
                • February 1, 1984
                • 460
                #22
                Re: M20 or M21
                Serial #1866, built 9/28/66
