M20 or M21 - NCRS Discussion Boards
M20 or M21
  • Jeff B.
    • April 30, 1980
    • 169
    M20 or M21
    Am trying to authenticate the Muncie 4-Spd in my 67 - 427-390 A/C coupe, #8902, built F23 (Jan 23).
    The case number is 3884865. Date stamp is P7S23, and vin stamp 7S108902. However, the metal tag # is 3880853. This tag number is referenced to a 327-350 engine with an M21. The rear end is stamped 12/29/66 AZ, indicating a 3.55. I understand that a 3.55 should have an M20. Did the big block Muncie trans use a different tag # than the small blocks?
    I bought this car in 1978 and it seems to be totally unmodified in any way, yet the trans metal tag # is confusing.
    Any thoughts?
    Jeff
    1967 Coupe 427-390 w/air
  • Mark F.
    • July 31, 1998
    • 1581
    Re: M20 or M21
    Originally posted by Jeff Bartlett (3541)
    Am trying to authenticate the Muncie 4-Spd in my 67 - 427-390 A/C coupe, #8902, built F23 (Jan 23). The case number is 3884865. Date stamp is P7S23, and vin stamp 7S108902. However, the metal tag # is 3880853. This tag number is referenced to a 327-350 engine with an M21. The rear end is stamped 12/29/66 AZ, indicating a 3.55. I understand that a 3.55 should have an M20. Did the big block Muncie trans use a different tag # than the small blocks? I bought this car in 1978 and it seems to be totally unmodified in any way, yet the trans metal tag # is confusing. Any thoughts? Jeff
    Jeff,
    The chart below is from the Hobby Kit the GM Heritage center offers called the Model Specifications Book with 390 HP circled.
    According to it, I believe the 350 HP could only come with a wide ratio trans (M20) if the diff was 3.55 in a Corvette (have no idea about other Chevy applications and that trans)
    And, I also believe your 390 HP only came in a close ratio trans (M21) if the diff was 3.55.
    That being said, this chart looks goofy to me because it doesn't have 4.11 diffs w/ 390 & 400 HP BBs, which I thought were available...
    The publication date on this was September 1966, so maybe things changed as the model year progressed (dunno ?)
    thx,
    Mark
    • Ray K.
      • July 31, 1985
      • 375
      Re: M20 or M21
      Jeff,
      Seems to me that the number #3884865 you are calling the case number is actually the side shifter cover with the correct number being #3884685.
      The main case number should be #3885010. You should read the well prepared 4 speed transmission article by Joe Tripoli in the latest issue of the Corvette Restorer magazine (Volume 50 #3 ). His information identifies your transmission as a close ratio 2.20 which is also confirmed by the metal tag with the #3880853. My P & A catalog ( 1967 ) also supports the tag #3880853 as being as a close ratio transmission.
      Hope this helps,
      Ray
        • 15706
        Re: M20 or M21
        It's easy to differentiate the WR from CR by the following method.
        1. Observe vehicle speed at 3000 RPM in third gear.
        2. Observe revs at the above speed in fourth gear.
        3. If 2000-2100 the trans is WR and CR if 2300-2400.
        I have no doubt that the powertrain chart is accurate. A 4.11 axle would be ridiculously short for the torquey 390/400 HP 427s and neither was considered a "racing engine".
        The AMA specs were an "engineering document" and maintained throughout the model year. Many years clearly show revisions. I've see a few data points in some of the AMA specs that I suspect are errors, but they are pretty rare compared to the errors I've seen in service manuals and P & A catalogs.
        • Gary S.
          • July 31, 1991
          • 37
          Re: M20 or M21
          Any thoughts?
          Jeff
          Jeff, FWIW, my L36 390hp '67 was built with an M21 and 3.55 rear gear.
          I don't remember seeing any depiction of a midyear L36 that was built with a 4.11, but I've probably only seen a few dozen.
          Gary
          • Mark F.
            • July 31, 1998
            • 1581
            Re: M20 or M21
            These are Noland's counts for '67...
            PS - they don't add up to 22,940
            ECL G81 - Positraction Rear Axle Count Tranny
            BA 3.08 ratio with Base Engine and Manual Transmission 820 3-Spd or M20
            JA 3.08 ratio with Base Engine and Manual Transmission or L36 1,161 M20 or M21
            DA 3.08 ratio with L88 and M22 0 Rock Crusher
            CA 3.36 ratio with Base Engine or L79 w/ M20 my bad, M20 is Wide> 5,952 WIDE Ratio
            KA 3.36 ratio with L36 or L71 2,235 Close Ratio
            LA 3.36 ratio with L88 and M22 2 Rock Crusher
            EA 3.55 ratio with L79 749 Wide Ratio
            MA 3.55 ratio with L36 or L71 with M21 1,635 Close Ratio
            XA 3.55 ratio with L36 and M35 23 Powerglide
            VA 3.55 ratio with L88 and M22 3 Rock Crusher
            FA 3.70 ratio with L79 and M20 2,597 Wide Ratio
            NA 3.70 ratio with L36 or L71 with M21 3,025 Close Ratio
            YA 3.70 ratio with L36 and M35 36 Powerglide
            SA 3.70 ratio with L88 and M22 4 Rock Crusher
            PA 4.11 ratio with L71 and M21 1,572 Close Ratio
            GA 4.11 ratio with L79 and M21 483 Close Ratio
            TA 4.11 ratio with L88 and M22 6 Rock Crusher
            UA 4.56 ratio with L88 and M22 5 Rock Crusher
            Last edited by Mark F.; January 22, 2024, 03:19 PM. Reason: M20 is wide ratio, not close as previously listed
            thx,
            Mark
            • Leif A.
              • August 31, 1997
              • 3647
              Re: M20 or M21
              Mark,
              Noland doesn't list the "AS" ECL that I have in my June '67 built L79, M21 with 3.70 open diff.
              Leif
              • Mark F.
                • July 31, 1998
                • 1581
                Re: M20 or M21
                Originally posted by Leif Anderson (29632)
                Mark, Noland doesn't list the "AS" ECL that I have in my June '67 built L79, M21 with 3.70 open diff.
                Hi Leif,
                I agree, but...
                If you look at Table C-4 in the latest TIMJG on page 208 you'll see the ratio code "AS" is listed, but it is in the "Open non-posi" category.
                The data Noland has for what I posted is only for G81 posi's...yours w/o posi would not appear in his data for that OPTION (G81) IOW, yours is a base diff - not posi, so he apparently didn't have counts broken out like that, but I'll go back and look to see if it's listed somewhere else under the Base discussions.
                PS - His counts fall short of the 22,940 total '67 production, so if his numbers are right, it would appear there were ~2,600 open diffs made in '67.
                does this all this make sense ?
                thx,
                Mark
                • Leif A.
                  • August 31, 1997
                  • 3647
                  Re: M20 or M21
                  Mark,
                  It sure does...
                  Leif
                  • Jeff B.
                    • April 30, 1980
                    • 169
                    Re: M20 or M21
                    Thanks to all for your insights. I did read the excellent article by Joe Tripoli, but could not determine for sure if 3.55 ratio Corvettes could be had with an M21. I also wonder that if (in 1967) you went to a dealer to custom option your Corvette, could you choose your 4 Speed trans as an M20 or M21? Or did you simply indicate your wanted the "4 speed" option, and St. Louis picked an M20 or M21 based on the rear end ration you chose?
                      • 15706
                      Re: M20 or M21
                      As you can see in the post #2 chart both the 390 and 400 horsepower 427s could be order with either WR or CR 4-speeds or PG.
                      Whether a customer special order or dealer stock order the first thing selected once an engine selection was made was the transmission type. Then you either went with the standard axle ratio or any of the optional ratios that you see in the chart, and all required Positraction, which was a mandatory option for all big blocks engine regardless or transmission type as you can see from the ** footnote.
                      • Jack M.
                        • March 1, 1991
                        • 1187
                        Re: M20 or M21
                        FYI- Perhaps these 1967 Corvette ordering excerpts might help, and be easier to read...
                        As overall, the dealer and customer had many options, to customize their order (based on listed availability).
                        And if something changed during the year, the Regional Zone would likely kick-back the order, to the initial dealer.
                        This image is part of the 1967 Corvette Dealer Order Form (dated 8-66):
                        And is image comes from the early 1967 Finger-Tip Facts (dealer only album):
                        • Gary B.
                          • February 1, 1997
                          • 7060
                          Re: M20 or M21
                          In Noland’s chart I don’t find L79, with 3.36 posi, and wide ratio, M20. But in the last chart that Jack posted, that combination is there. My ‘66 has that combination. Did that combination disappear for ‘67? Or is Nolan’s chart incorrect?
                          Gary
                          Last edited by Gary B.; January 22, 2024, 04:01 PM. Reason: Corrected wide ratio tranny to M20 from incorrect M21
                          • Gary C.
                            Administrator
                            • October 1, 1982
                            • 17865
                            Re: M20 or M21
                            Gary,
                            Depends on which data Noland used. Sometimes he used preliminary marketing data, which could and did change throughout the model year.
                            Noland's books are good "guidelines", but they're not the "ends all be all".
                            Gary
                            NCRS Texas Chapter
                            https://www.ncrstexas.org/
                            • Jack M.
                              • March 1, 1991
                              • 1187
                              Re: M20 or M21
                              It appears Noland listed OPTIONAL G81 rear ends... as also mentioned in the 1967 Production Trends.
                              Speculating there would be no individual ECL's for STANDARD equipment, so those axle ratios were omitted from his chart.
                              This image lists the various 1967 Rear Axle Codes (not the ECL code):
                              NOTES observed in Spec Manuals:
                              1967 "AQ" and "AR" codes & ratios possibly have been used early in the 1967 model-year, or not at all.
