Trans mount - NCRS Discussion Boards
Trans mount
  • Carmelo P.
    • May 9, 2016
    • 54
    Trans mount
    Can someone post a picture of
    original transmission rubber mount bolts and washers?
    Size is 7/16-14 with thick washers I'd like to know headmarks and if flat or indented heads...
    Thanks.. 1967 Muncie
  • Gary B.
    • February 1, 1997
    • 7070
    • Carmelo P.
      • May 9, 2016
      • 54
      Re: Trans mount
      Bolt #5, bolt #9, washer #7
      Thanks Gary,
      I have the AIM, searching I couldn't find a pic of the bolt or headmark.
      Need the bolts and washers..
      • Gary B.
        • February 1, 1997
        • 7070
        Re: Trans mount
        Bolt GM 9419073: 7/16-14 x 1.0"; Gr. 5, dark natural or black phosphate; Hex head, trimmed; Headmark: A, M, probably others.
        All GM-discontinued.
        Gary
        • Robert P.
          • October 19, 2019
          • 321
          Re: Trans mount
          i believe Rich over on the corvette forum has the correct set restored for sale
          • Carmelo P.
            • May 9, 2016
            • 54
            Re: Trans mount
            ps, still looking for the A4 3/4 bypass hose clamps we discussed awhile ago...found 1
            • Leif A.
              • August 31, 1997
              • 3653
              Re: Trans mount
              Carmelo,
              Are these the bolts and washers you're asking about? If so, Rich Pasqualone has them for sale on his website.
              Leif
              • Gary B.
                • February 1, 1997
                • 7070
                Re: Trans mount
                Leif,
                Based on my research, the large, thick flat washers in the photo you posted should be unplated, and probably dark in appearance. They look to be zinc or cad plated in that photo.
                I believe the flat washers should have a similar hue to the bolts and lock washers (GM 103328) in that photo. Those lock washers were dark (not very different from black phosphate) from their heat treatment. The same hi-collar lock washers were used at most bumper attachment locations from 1965-1967. The repro vendors typically have zinc plated fasteners in their kits.
                Gary
                • Carmelo P.
                  • May 9, 2016
                  • 54
                  Re: Trans mount
                  Leif, yes that's the bolt and washer. Would your pictured bolt SBC be an original?
                  • Gary B.
                    • February 1, 1997
                    • 7070
                    Re: Trans mount
                    Carmelo,
                    SBC is one of several original headmarks.
                    Gary
                    • Gary B.
                      • February 1, 1997
                      • 7070
                      Re: Trans mount
                      • Leif A.
                        • August 31, 1997
                        • 3653
                        Re: Trans mount
                        Carmelo,
                        According to Rich, they are and I have no reason whatsoever to doubt his word.
                        Leif
