Heater box Restore and How to use Aero Rivet Tool - NCRS Discussion Boards
  • Keith M.
    • January 17, 2021
    • 695
    Well it is winter time so time to tackle the heater box restore and boy do I have questions.
    Trying to assess how much I want/need to tear it down. I cannot understand for the life of me why they did such a mix of screws and rivets. The end with the larger open end that sits against the firewall I can probably just soak in Evaporust to deal with all of that...being sure not to submerge actuators..but the narrower longer end I will probably want to take apart. Looks like I can do that by removing the metal plate. Thing is..that plate has X larger aluminum rivets, Y smaller rivets, and Z screws. I do have the seal kit from Doc Rebuild that includes aluminum rivets. So am thinking drill out all the rivets ideally with my bench drill press. But things I do no know are....where to get the smaller rivets? How to reinstall new rivets? I got the Aero Rivet II tool and have no idea how to use it. Came with zero instructions and there is NOTHING on the internet regarding how to use...no youtube....nada. It is essentially a C clamp style thing that needs to get on both ends of the rivet which is impossible for almost all the rivets on our cars. To summarize...
    My overall breakdown approach sound ok?
    Where do I get the smaller rivets?
    How to I get new rivets installed?
    Thanks in advance!
    Keith
    late Oct 1969 L46 350/350, M21 4spd, 3.70 posi convertible --As with life, restoration is a journey, not a destination. Though restored cars provide both journeys AND destinations!
  • Harry S.
    • July 31, 2002
    • 5342
    Re: Heater box Restore and How to use Aero Rivet Tool
    Doc Rebuild...
    1963-1967 Corvette Deluxe Heater Box Seal Kit USA includes semi tubular Rivets plus 9 die cut sponge rubber & foam seals A-2B-C-D-E-F-2G. Best of all, includes schematic instructions. Made in Bridgeport, CT USA. Do not order this kit if you have AC. None of the parts are the same.
    Some of the rivets will not be installed with the tool. You will need four hands and a bench vise, a hammer and a rivet punch. One person holds the box, the other installs the rivet. Do NOT hit the rivets hard, you will break the fragile fiberglass.
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11362
      Yes, Dr Geoff has the best kit for the heater box, and other unique parts I've acquired when I was restoring the cars.
      Rich
      • John W.
        • December 15, 2015
        • 63
