gas gauge - NCRS Discussion Boards
gas gauge
  • Jeffrey G.
    Infrequent User
    • April 22, 2016
    • 19
    gas gauge
    I'm working under the dash of my 64 convertible. Is it reasonable to think I can remove the gas gauge and amp gauge without removing the cluster?
  • James W.
    • December 1, 1990
    • 2679
    Re: gas gauge
    Well... if you are limber and have very small hands if might be possible, but not recommended. I would loosen the gauge cluster, pull it back and "hang" it on two (2), 6 inch x 1/4-20 threaded rods so you can get your hand and tools in there to remove the screws that hold those two gauges in the cluster. I would also remove the drivers seat and the stirring wheel.
    James
    • Bill M.
      • 1330
      Re: gas gauge
      Jeff you may get them out but you will never get them back in. Do as James says.
      • Jeffrey G.
        Infrequent User
        • April 22, 2016
        • 19
        Re: gas gauge
        Thanks. Will do
        • Jeffrey G.
          Infrequent User
          • April 22, 2016
          • 19
          Re: gas gauge
          The seat is out. I'll take your advise.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11367
            Re: gas gauge
            I've actually done it several times. However, my body is in the category of being smaller than most, which is a clear disadvantage when my friends ask me to help them. 😅
            Rich
            • Gary B.
              • February 1, 1997
              • 7082
              • Richard M.
                Super Moderator
                • August 31, 1988
                • 11367
                Re: gas gauge
                That made me laugh. I think i did that once!
                Yes. You too.... Rich
