C2 Battery - NCRS Discussion Boards
C2 Battery
  • Raymond R.
    • June 30, 1988
    • 115
    C2 Battery
    Has anyone purchased a Delco 24PG battery lately? I am located in Northern New Jersey. Looking for somewhere I may purchase one. It is for a 1963 Corvette.
    Has anyone had experience with Battery Central Mall, Antique Auto Batteries? Wondering how they are performing.
    Thanks.
  • Harry S.
    • July 31, 2002
    • 5349
    Re: C2 Battery
    Ray, I kinda feel a Delco is a Delco. In November the Group 24 in my 63 died. I looked for one here, New Hampshire, but found they were no longer available. Instead a Group 34 was available. Essentially the same except the profile is 1 inch shorter, making it much easier to install. Also, I believe if you are having the car judged, there is no additional point deduction over a Group 24.
    What part of Northern NJ, I'm from Paramus?
    • Raymond R.
      • June 30, 1988
      • 115
      Re: C2 Battery
      Thanks for a speedy reply, Harry. Are there any other identifiers for the Group 34 battery you purchased? The recommended Group 24 was a Group 24 PG. Are there letters or other identifiers after Group 34?
      I live in Lake Hopatcong, NJ (Morris County). I have owned my 63 SWC, since December 1987. Took it out for a ride today. Temperature was in the low 40s.
      • Harry S.
        • July 31, 2002
        • 5349
        Re: C2 Battery
        Ray, I can't recall and I can't get to the car. It's now parked in storage for the winter.
        From the receipt.
        • Larry E.
          • 1703
          Re: C2 Battery
          Group 24 Delco Battery can be purchased at any Menards Store. Just had them for sale here
          (Central Illinois) for $99. FYI>>Larry P.S. There are 336 Menards stores in the United States as of November 28, 2023.
          Larry
          LT1 in a 1LE -- One of 134
          • Harry S.
            • July 31, 2002
            • 5349
            Re: C2 Battery
            After installing the group 34, I'd never try a group 24 again. The 34 went in like butter, the 24 is like an anchor.
            • Raymond R.
              • June 30, 1988
              • 115
              Re: C2 Battery
              Thanks Harry. I appreciate your response.
              • Raymond R.
                • June 30, 1988
                • 115
                Re: C2 Battery
                Thanks Larry. I will take a look and see what i can find.
                • Raymond R.
                  • June 30, 1988
                  • 115
                  Re: C2 Battery
                  Thanks for the advice, Harry.
                  • Ray G.
                    • May 31, 1986
                    • 1189
                    Re: C2 Battery
                    Autozone sells AC DELCO batteries.
                    I hope you dance
                    • Bruce G.
                      • May 31, 2003
                      • 78
                      Re: C2 Battery
                      IMG_0112 (1).jpg10 years ago bought replica tartop battery from I think Antique Auto Battery.............not sure if still in business, never used trickle charger and after this long still starts every time even after setting through the winter months. Luck or good quality................not sure, but extremely satified. Bruce
                      • Troy P.
                        • February 1, 1989
                        • 1284
                        Re: C2 Battery
                        Went I asked about the correct maintenance procedure for their repro batteries I was told not to use a trickle charger. There is an AGM glass mat battery inside. If you have a smart charger, they suggested starting the charge on 10 amps and charging for 90 minutes every other month for 1 hour. But if yours has lasted 10 years I'd say keep doing whatever you are doing...which is apparently nothing.
                        No battery disconnect switch shown in the photo. Are you using one?
                        • Bruce G.
                          • May 31, 2003
                          • 78
                          Re: C2 Battery
                          IMG_0685.jpgYes, blade battery disconnect.................hidden in other photo. B
                          • Raymond R.
                            • June 30, 1988
                            • 115
                            Re: C2 Battery
                            Thanks Ray. I appreciate letting me know.
                            • Raymond R.
                              • June 30, 1988
                              • 115
                              Re: C2 Battery
                              Thanks Bruce. Glad you had such good luck with your battery. Hope I am as lucky with my next one.
