1970 LT-1 Alternator Pulley - NCRS Discussion Boards
    • 43296
    Re: 1970 LT-1 Alternator Pulley
    Originally posted by James Groome (65120)
    Here is the original on my LT1.
    [ATTACH=CONFIG]119462[/ATTACH][ATTACH=CONFIG]119463[/ATTACH]
    James------
    Would you please measure and post the exact OD of this pulley?
    • Gary B.
      • July 31, 1979
      • 926
      Here is the pulley on my 70, July 7th build. It measures 3.202" diameter and approximately 0.838" thick.
      Gary Bosselman
        • 43296
        #18
        Gary Bosselman
        [ATTACH=CONFIG]119586[/ATTACH]
        Gary------
        The OD and thickness are about right. However, the aspect that seems unusual to me is the fact that the wider belt guide appears to be on the outer side and the thinner belt guide appears on the inner side. I have not noted that before, including the previously posted photos in this thread.
        • Gary B.
          • July 31, 1979
          • 926
          #19
          Another picture... The front (closest to the radiator measure .120, the rear (closest to alternator housing) measures about .180"
          I've owned the ole car since 1979. I know the alternator's been off when I rebuilt the water pump, but it's never been apart. I'll get a picture of Terry's tomorrow and post it. His is a Jan. 29th car.
          Gary B
            • 43296
            #20
            Gary B
            [ATTACH=CONFIG]119592[/ATTACH]
            Gary------
            Yes, in this better photo it appears as I would expect.
            • Gary B.
              • July 31, 1979
              • 926
              #21
              Terry's January 29th, 70 LT-1 is like my July 7, 1970 car. Not significantly different.
              Measures about 3.2" in diameter. About 0.190 on the rear and 0.130 on the front.
              Just a FWIW....
              Gary B
              • Bob H.
                • July 31, 2000
                • 829
                #22
                i The first photos look like the adjust bracket is on the wrong side of the alternator and the alternator looks good. The restored car alternator looks great but I got dinged for it being painted and not "natural" like your first car So, I undid my pretty work! BTW, I now have the correct pulley!
                • Leonard M.
                  • September 7, 2009
                  • 236
                  #23
                  "That alternator had the look of being untouched until I put my hands on it, to clean it, as seen by the adjuster bracket."
                  Yes, you are correct. That alternator had no evidence of ever being removed when I bought the car, but I removed it to clean and re-installed it with the adjuster bracket on the wrong side. Before realizing my mistake, the belt alignment didn't stand out as being off and the belt didn't squeel.
                  • Bob H.
                    • July 31, 2000
                    • 829
                    #24
                    Purchased 831 repro from Heartbeat and it would not slip on the shaft. I got one through Jegs but made by OER. Looks good and fit perfectly
                      • 43296
                      #25
                      Bob------
                      If you are able, please accurately measure the ID of the Heartbeat pulley.
