I am trying to determine what the correct pulley is for my car. I know it should be a deep V zinc plated pulley. Answers on the internet are all over the place. I was looking at several that are either 3829387 or reproduction of it. It lists all high performance applications except the 70 LT-1. Others say a 180. Then I see many repros that don't have a key slot which I am not sure is correct. Does anyone know the correct size, etc? My alternator is the correct 884
1970 LT-1 Alternator Pulley
Re: 1970 LT-1 Alternator Pulley
Bob-------I am trying to determine what the correct pulley is for my car. I know it should be a deep V zinc plated pulley. Answers on the internet are all over the place. I was looking at several that are either 3829387 or reproduction of it. It lists all high performance applications except the 70 LT-1. Others say a 180. Then I see many repros that don't have a key slot which I am not sure is correct. Does anyone know the correct size, etc? My alternator is the correct 884
The original pulley for your application was GM #1970831 which is a Delco-Remy part number. This was a machined steel, clear zinc plated pulley of 3-3/16" OD with no keyway slot. It had no stamped part number. It was discontinued from SERVICE in November, 1984 and replaced by GM #3844100. The latter was a pre-existing Chevrolet part number originally released about 1964. It's virtually identical to the 1970831 except that its diameter was 3-7/32". I do not recall if the 3844100 had a keyway, or not. Either way, it's a moot point because a keyway is not necessary for ANY Corvette application and the presence or absence of a keyway cannot be discerned when the pulley is installed.
By the way, it's even possible that the 3844100 was used alternately with the 1970831 in PRODUCTION but I have no proof of that.
The reproductions of either of the above pulleys are very good and very close to the original configuration. The one difference is a very minor difference in the configuration and width of the belt guides. Functionally, they should work perfectly, though. Whether judges can discern the difference, I know not.In Appreciation of John Hinckley- Top
My 70 LT-1 884 alt. Pulled for repair.
Screenshot_20231112_183854_Gallery.jpg- Top
- Top
First 2 pictures are from my CTU Jan. car. That alternator had the look of being untouched until I put my hands on it, to clean it, as seen by the adjuster bracket. Second 2 pictures are of my current CTK car that was restored, but I feel the pully is correct. Both measured 3 3/16" with no key slot or stamped numbers.
I recall Gary Bosselman did research on the pullies that were used back then.
1100884front.jpg1100884date.jpgDSCN7987.jpgDSCN7991.jpg- Top
No, I'm not. Sent it out for what I thought was a bad bearing. Turns out the bore in the front cover was out of round. Have no idea how that could happen. Maybe wrong pulley?
Ken Bruno did an amazing repair.- Top
James A Groome
1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453- Top
Dennis------
What is the exact OD of this pulley?In Appreciation of John Hinckley- Top
I have ordered one that is supposed to be made exactly to the 831 specs. Thanks for the input. I'm going to compare my fan to yours as long as you believe it is original. Just trying to correct as much as possible pointed out during judging. Most are simple fixes- Top
Where are you getting the pulley Bib?I have ordered one that is supposed to be made exactly to the 831 specs. Thanks for the input. I'm going to compare my fan to yours as long as you believe it is original. Just trying to correct as much as possible pointed out during judging. Most are simple fixes- Top
Dennis------
It's not a GM #1970831 or GM #3844100. So, what could it be? I really do not know. Might be a GM#3883978 or GM #3906329. I think even more likely, based on configuration, is that it's some sort of aftermarket pulley.In Appreciation of John Hinckley- Top
Dennis------
I think it should be functionally fine. As long as the pulleys reasonably align (which I'm pretty sure they do) there should be no functional problem. As far as a small difference in OD from original, that should present absolutely no functional problem, at all.In Appreciation of John Hinckley- Top
