1956 headlight rings - NCRS Discussion Boards
  • Sheldon S.
    • March 1, 1999
    • 476
    My 56 is a very early vin number and the headlight rings the hold the bulb in place do not have any tabs to hold bulb in place. After looking at corvette central I see you can buy these types of rings but I don't understand what holds them in place. It has been apart for many years.
    Sheldon
  • Leif A.
    • August 31, 1997
    • 3633
    Re: 1956 headlight rings
    Sheldon,
    Do you have the bulb retainer rings?
    Leif
    • Sheldon S.
      • March 1, 1999
      • 476
      Yes I have the bulb retainer rings, which don't have any tabs like later years to screw them to the headlight capsule. That's what I find puzzling. At first I just thought the tabs had fallen off but there is no spot for them to screw onto capsule even if there were tabs.
      • Mark S.
        • July 31, 1983
        • 660
        A solution might be to use the later year rings and tap them into the capsule. These rings changed late in 56 to the 57 models.
        • Sheldon S.
          • March 1, 1999
          • 476
          I am curious though how they were originally attached to the capsule.
          • Mark S.
            • July 31, 1983
            • 660
            Does your ring have a tab and a spring? The tab goes into a slot and the spring attaches to a hole.
            • Sheldon S.
              • March 1, 1999
              • 476
              Yes there is a tab sticking out of the capsule on one side. Ill go have a closer look
              • Sheldon S.
                • March 1, 1999
                • 476
                Thanks for info Mark. Yes the tab was there and the spring and it all makes sense now,
                • Mark S.
                  • July 31, 1983
                  • 660
                  You are very welcome!
