1970 washer squirters - NCRS Discussion Boards
  • Bob H.
    • July 31, 2000
    • 807
    I got my washers to work including the headlights but the ones on the windshield just dribble. Is there a way to open them up or make them work better?
    BTW, I entered the prestigious Lake Mirror Concours d'Elegance held on Saturday. I was absolutely in shock when I was told I won Best of Show!
  • Leif A.
    • August 31, 1997
    • 3627
    Re: 1970 washer squirters
    Congratulations, Bob, on your Concours Best of Show...quite the honor!! A welding tip cleaner is what I have used to gently clean out the washer nozzles. They don't get used much (if at all) and they close up over time.
    https://www.amazon.com/Herain-Carbur...8-6561437?th=1
    Leif
    • Bob H.
      • July 31, 2000
      • 807
      Thanks Leif. I actually have a set of those I have used so many times over the years. Didn't know what thats what they really were. So the opening should be large enough to use one of these? They look closed up. Are they supposed to be flat on the tip?
      • Chris H.
        • April 1, 2000
        • 837
        Word of caution on opening up squirter orfices. I did that on my 70s wiper arm and unfortunately made the hole too big so it sucked too much fluid volume from the other 4 squirters so that they barely worked. So if you do go that route open up the plugged orifice in tiny increments.
        • Bob H.
          • July 31, 2000
          • 807
          Thanks Chris
          • Bob H.
            • July 31, 2000
            • 807
            I got the holes on my squirters opened up and flowing but now another question. On the passenger side I discovered there are 3 holes. Two are of course parallel to the windshield. Looking down at the squirter, the third is on top so it shoots fluid virtually straight up. It appears exactly the same size as the other holes. Should it be there ?
            • Gary B.
              • July 31, 1979
              • 926
              The squirters should have three holes. One pointing up the windshield (parallel to the windshield), one pointing down to the windshield (perpendicular to the windshield), and another point down the windshield, parallel. I think GM engineers were thinking of the wind pushing them onto the windshield.
              I've used some heat on the tubes to dissolve the junk in the tubes. Use a needle to open up the holes.
              Gary B
              • Bob H.
                • July 31, 2000
                • 807
                Thanks Gary. Guess I need to look for the third on the other side!
                • Larry E.
                  • 1677
                  FWIW; After using PB B'laster to get my washers squirters opened up (C2) I found out
                  that it still did not work correctly. It turned out to be I needed new hoses leading up to
                  the squirters. Replaced them and everything worked out correct. JMHO>Larry
                  Larry
                  LT1 in a 1LE -- One of 134
                  • Brady C.
                    • November 1, 2004
                    • 112
                    Brady Como
                    #42793
                    • Bob H.
                      • July 31, 2000
                      • 807
                      Well, the judges better stand back!
