63 horn wires - NCRS Discussion Boards
63 horn wires
  • Todd L.
    • November 25, 2020
    • 294
    63 horn wires
    Hey guys,
    I have a mostly original 63 coupe for reference and am restoring another 63 coupe for NCRS judging. I am questioning the wire colors for the horn contact, they both have green coming from the horn button, but a black with the connector on the lower section of the column. Is this correct? If so, how would this have been connected at the factory? The driver car I have is just twisted together with black electrical tape over the connection, doesn't seem like the factory would have done that in my opinion. Has this been modified on both cars I have by chance? Any help would be appreciated.
    Todd
  • Harry S.
    • July 31, 2002
    • 5330
    Re: 63 horn wires
    Todd, the factory would not have done that. As far as I know all original wire for the horn from the upper bearing to the connection was black. Additionally the connection was a quick plug.
    I've attached four pictures from a Chevy replacement kit. Amazing as to what it says. Additionally, the wire in the kit is green.
    So what is the fix. Take the Chevy kit, cut off the bottom connector, use a black magic marker and color the wire black, attach the correct connector, then install the new part.
    • Todd L.
      • November 25, 2020
      • 294
      Re: 63 horn wires
      Thank you so much for the detail Harry! I appreciate the help, hope you are well.
      Todd
      • Danny P.
        • June 30, 2002
        • 344
        Re: 63 horn wires
        Todd ,what month of 63 do you have on very early cars , i show from horn button wire at the wheel is Tan to fuse connector, then fuse box to relay is still tan, both horn units are both black wire.
        • Joseph S.
          National Judging Chairman
          • March 1, 1985
          • 886
          Re: 63 horn wires
          Todd, I'll second Danny's info. The wire coming from the steering column should be tan. Plugging into the tan lead heading out to the Horn Relay.
          Regards, Joe
          • Todd L.
            • November 25, 2020
            • 294
            Re: 63 horn wires
            Thanks Danny, I am a little confused by your last statement that " both horn units are both black wire." Could you clarify please?
            Everything else sounds like it should be tan?
            • Todd L.
              • November 25, 2020
              • 294
              Re: 63 horn wires
              Thanks Joe! Good to hear from you, hope all is well.
              • Danny P.
                • June 30, 2002
                • 344
                Re: 63 horn wires
                Todd, follow your engine harness from the fire wall plug going along the right side inner fender toward the radiator support, there a black wire that split with 2 connector wire for each horn , look at the photos yellow arrow on top pointing at the black wire that goes over support down with 2 frame clips and 2 connectors for each horn the Tan wire is part of the same harness but it connect to the relaythumbnail (2)_inPixio.jpgthumbnail.jpg
                • Todd L.
                  • November 25, 2020
                  • 294
                  Re: 63 horn wires
                  That makes sense Danny, I think the harness I have is good from the firewall foreward, it is the one for the horn button that I am questioning. I appreciate the detailed pictures.
                  Todd
                  • Danny P.
                    • June 30, 2002
                    • 344
                    Re: 63 horn wires
                    Maybe you have a horn button from a later year Todd
                    • Todd L.
                      • November 25, 2020
                      • 294
                      Re: 63 horn wires
                      They both appear to be replacements. Oct. 19th and Dec. 4th of 1962 are the build dates.
