1958 fan motor - only one speed works - NCRS Discussion Boards
  • Daniel J.
    • July 29, 2007
    • 158
    Need help...working on a '58.
    The fan motor only works on one speed.
    Could it be the control switch since the motor only has one hot wire connecting it?
    Thanks, Dan
  • Jimmy G.
    • November 1, 1979
    • 977
    Re: 1958 fan motor - only one speed works
    Check the Resistor on the back side of the switch
    • Daniel J.
      • July 29, 2007
      • 158
      Jimmy,
      Are you saying to check connections or to test the resistor? (is there a testing method you recommend?)
      Thanks, Dan
      • Jimmy G.
        • November 1, 1979
        • 977
        Both Ohmmeter Simple test
