'66 AIM Missing L72 Pages - NCRS Discussion Boards
  • Mike B.
    • July 31, 1994
    • 843
    Hello Everyone,
    Does anyone out there have the following '66 AIM pages? My old Mid America copy and all other guys I've contacted with that company's version are also missing UPC L72 sheet D3 & D4. One of these pages shows the L72's HD differential side yoke to halfshaft caps & bolts. Sure would appreciate these two missing pages. Probably found in an early "Graphic Design" '66 AIM? Scanned copies here would be excellent!
    Mike
  • Mike T.
    • January 1, 1992
    • 568
    Re: '66 AIM Missing L72 Pages
    Mike - I just looked at my 66 AIM, probably purchased back in the early 90s and it's also missing those pages. It has D2 and then D5 but no D3 or D4. How did you figure out what pages were MIA?
    Mike T. - Prescott AZ.
    • Mike B.
      • July 31, 1994
      • 843
      Hi Mike,
      An educated guess that's backed up by the fact that the '65 and '67 AIM both show the big block differential pages listing the HD differential caps and bolts. Another strong reason that I feel these pages exist is that Don Olson cites the cap bolts listed on one of those sheets under his very accurate AIM database. The cap bolts show on his listed '65, '66, and '67 AIM pages.
      When I get home this afternoon I'll list the cap bolt part number and dimensions unless someone beats me to it.
      Again, thank you Don for this excellent cross reference source!
      Mike
      • Ray K.
        • July 31, 1985
        • 373
        Mike & Mike,
        My '65 AIM shows the cap and bolts under UPC L78, D4, page 319.
        Cap is #3872909, Bolt is #180126. Dimensions are not clear. I know from experience that it is 3/8" x 16 approx 1 1/4 to 1 1/2 (? ) length.
        I can provide a copy of this page if needed.
        Ray
        • Mike B.
          • July 31, 1994
          • 843
          Hi Ray,
          Thanks for the info. Here's the '65 AIM page you're referencing. I've had it placed in my '66 AIM since this info was missing from my Mid America copy. GM Engineering Standards lists bolt #180126 under 280-M Steel (Grade 5) Hexagon Bolts. It's dimensions are listed there as 3/8-16 x 1-1/2" inches long plated in zinc.
          My '65 AIM lists bolt #180126 under UPC L78 sheet D4 item 2
          My '67 AIM lists bolt #180126 under UPC L36 sheet A12 item 2
          Don's '66 AIM lists bolt #180126 under UPC L72 sheet D3 item 2
          So I assume there must be an actual '66 AIM page referencing these bolts and caps. I'd really like to add them to my old '66 AIM that's missing these 2 pages. UPC L72 sheets D3 and D4.
          Thanks, Mike
          • Gary B.
            • July 31, 1979
            • 926
            From a very old AIM.
            • Mike B.
              • July 31, 1994
              • 843
              Thanks Gary for Sheets A3 & A4. Do you have UPC L72 Sheets D3 & D4? These are the ones I'm looking for. Hopefully your old AIM will have these pages.
              Mike
              • Gary B.
                • July 31, 1979
                • 926
                I have two old 66 AIM's. One is the old Review Graphics and the other is a Mid-America copyrighted 1975.
                Neither have the D3 & D4 pages in them.
                Gb
                • Mike B.
                  • July 31, 1994
                  • 843
                  Thanks Gary for checking your two AIMs. Much appreciated. Maybe we'll get lucky and someone will post those missing '66 AIM pages here.
                  Cheers, Mike
                  • Keith B.
                    • September 15, 2014
                    • 1583
                    would those sheets be under RPO L36?
                    • Mike B.
                      • July 31, 1994
                      • 843
                      Keith,
                      '65 they were in L78 section
                      '66 they were in L72 section
                      '67 they were in L36 section
                      Mike
                      • David Z.
                        • April 1, 2002
                        • 181
                        PDF (8.5 x 11) versions are attached.
                        Dave Z
                        Dave Zuberer
                        • Mike B.
                          • July 31, 1994
                          • 843
                          Thanks Dave for resizing and posting these PDF versions. Everyone should be able to print these missing '66 AIM pages now!
                          Mission complete. Mike
