Plug wires for 63 fuelie. - NCRS Discussion Boards
  • Gerald J.
    Infrequent User
    • January 22, 2018
    • 22
    Looking to replace my Lectric Limited wires. Want 90 - 90 wires that will fit under the stock shielding. Prefer pre-made wire set, but will fab them if necessary.
    Jerry
  • Dan H.
    • July 31, 1977
    • 1372
    Re: Plug wires for 63 fuelie.
    I replaced mine with Summit racing spiral wound set, had to cut to length and also used LL dist boots on top, runs vastly better than the LL wires ever could.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Paul Y.
      • September 30, 1982
      • 570
      I have been using magnacore with good results.
      It's a good life!
      • Mark E.
        • April 1, 1993
        • 4610
        If judging isn't a concern, spiral-core wires like those recommended by Dan and Paul are a great choice. Minimal resistance, durable, minimal RFI. If you don't have a radio, solid-core like Packard 440 is a good choice.
        OEM wires use a fiber core impregnated with carbon particles as a conductor, a design that has significant, inconsistent resistance, and breaks down with heat, handling, and age.
        Whatever you choose, check resistance of each wire before installation. Sometimes you get a bum wire.
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • John D.
          • December 1, 1979
          • 5507
          Joe Lucia gave us this info long ago. Delco 2987482 . Fit perfect. Watch them on line. Fit perfect. John
          • Mark E.
            • April 1, 1993
            • 4610
            Assuming they look like the originals and you can find this obsolete part number, they may be good for judging. But they are old-time suppression core wires, so not the best construction.
            If a pre-cut and ready to install set is important, check out this outfit offering modern spiral-core made to order: https://firecoreperformance.com
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
