1963 shifter anti-rattle nylon insert - NCRS Discussion Boards
  • Gerald C.
    • June 30, 1987
    • 1321
    Many years ago, I saw an article that would help reduce the rattling in a 1963 shifter. It showed that making a thin nylon "plate" that resembled one side of the shifter body. I cannot locate that article, so if anyone can remember seeing it, can you forward it to me? I know there is a Technical Article describing the process, but as they say "a picture is worth a 1,000 words"!
    • 6960
    Re: 1963 shifter anti-rattle nylon insert
    Jerry if you have the 4th edition JM it was a TSB in back of manual.
    • Gerald C.
      • June 30, 1987
      • 1321
      Ed,
      I don't have the 4th edition of JM, but I do have the TSB. I was looking for the diagram.
        • 6960
        Originally posted by Gerald Coia (11656)
        Ed,
        Jerry, the 3 Arms on shifter will need a thin nylon washer or a window crank fiber washer behind crank that has to be modified.I donโ€™t have the 4th edition either I gave it away.
        • Larry E.
          • 1703
          FWIW> Not saying this applies to the 63 Corvette But> Had a nice 63 Impala SS with 4 speed Muncie
          and it had a small spring attached to one of the arms on the shifter to keep it from "rattle". Remember
          it would brake ever so often and had to install a new one which was bought through the Chevy Parts Dept. at
          the dealer. Larry
          Larry
          LT1 in a 1LE -- One of 134
            • 15706
            My '63 T-10 has a small, stiff spring between a hook on the lever shaft and a small bracket attached to the bottom curved outside track. Actually it didn't have one from the factory, but I was able to order one in the late sixties when I discovered it was missing. It really helped mitigate the shifter buzz.
            • Gerald C.
              • June 30, 1987
              • 1321
              Thanks for everyone's feedback!
