Can the inlet needle and seat on a Holley 2818-1 / 4160 carburetor be replace without removing the float bowl? Sorry, I can’t change the thread title that reads 4150.  I can’t get the float level set so it stops leaking (flooding) into the primary side of carb. Also where is a good place to purchase an overhaul kit that doesn’t have blue gaskets in the kit? Actually, I’d like to find and buy replacement inlet need and seat assembly with the viton O-ring and needle. I believe the correct size is 0.097”?
James
James
