Holley 4150 Inlet Needle and Seat Replacement - NCRS Discussion Boards
  • James W.
    • December 1, 1990
    • 2668
    Can the inlet needle and seat on a Holley 2818-1 / 4160 carburetor be replace without removing the float bowl? Sorry, I can’t change the thread title that reads 4150. I can’t get the float level set so it stops leaking (flooding) into the primary side of carb. Also where is a good place to purchase an overhaul kit that doesn’t have blue gaskets in the kit? Actually, I’d like to find and buy replacement inlet need and seat assembly with the viton O-ring and needle. I believe the correct size is 0.097”?
    James
  • John F.
    • March 23, 2008
    • 2415
    Re: Holley 4150 Inlet Needle and Seat Replacement
    Here is where I got mine. Ebay # 265374292099. $54.95 plus shipping.
    • James W.
      • December 1, 1990
      • 2668
      Thankd for the information. Do the inlet needles in the kit have the viton tips?
      James
      • John F.
        • March 23, 2008
        • 2415
        I believe so. You could contact the seller.
        • Stephen L.
          • May 31, 1984
          • 3162
          Purchase a kit with the blue gaskets. Purchase a black felt tip pen and color the gasket edges black...... Takes about 30 seconds per gasket.......if you are slow......
          • Mark E.
            • April 1, 1993
            • 4602
            Make sure you correctly identify the model when ordering parts. The thread title says 4150 but the diagram in the image shows a 4160.
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
            • William F.
              • June 9, 2009
              • 1364
              Your problem might not be a bad needle and seat. Could be a pin hole in the float. Remove float, shake it to see if you hear gas inside. if not sure put float in a bowl of gas and see if float sinks which means it's full of gas. Less likely is too high fuel pressure.
              • William F.
                • June 9, 2009
                • 1364
                But to answer your question about replacing needle and seat, no, you can do this without removing float bowl
                • William F.
                  • June 9, 2009
                  • 1364
                  Please let us know if you found and fixed problem so rest of us can profit from your experience. Some may have same problem now or in future,
                  • James W.
                    • December 1, 1990
                    • 2668
                    William,
                    I will be getting back to working on the car next week. I bought the Viton tipped inlet need a seats from Holley along with the upper and lower fiber gaskets. I found locally the correct size Viton O-rings for the inlet need and seats. Holley could not tell me if the inlet needle and seats they sell were in fact equipped with the Viton O-rings. I plan to replace the O-rings on the new inlet need and seats with the Viton O-rings.
                    Will report back when I'm done.
                    James
