C2 small block starter bolt torque - NCRS Discussion Boards
  • Richard E.
    • 252
    Looking through my small library of C2 Corvette technical manuals I have located starter specifications, rebuild instructions, testing procedures, and wiring connection information but nothing regarding the starter mounting bolt torque specification. I suppose I have overlooked it somewhere, but I would appreciate if someone could provide the bolt torque specification and identify which Corvette technical manual it can be found in. Thanks in advance for the assistance!
  • Leif A.
    • August 31, 1997
    • 3658
    Re: C2 small block starter bolt torque
    Richard,
    The two starter bolts you're referencing are #3830134 which is a 3/8-16 X 3 5/8" Grade 5 bolt and #3/8-16 X 1.84" Grade 5 bolt. According to the chart show below, the torque for these bolts should be 30-35 lb ft.
    Leif
    • Ed S.
      • August 6, 2014
      • 1390
      Leif, that is a great chart. Can you post it as a PDF or provide a link to the website the chart is on.
      Thanks.
      Ed
      • Leif A.
        • August 31, 1997
        • 3658
        Thanks.
        Ed,
        You can right click on the chart in my post and "Save" it as a PDF.
        Leif
        • Richard E.
          • 252
          Thank you very much Leif.
          • Leif A.
            • August 31, 1997
            • 3658
            You're quite welcome.
            Leif
              • 43290
              Richard-------
              30-40 lb/ft. This can be found in the AIM as well as the factory service manual.
              Make sure you use the special, knurled shank starter bolts.
              • Leif A.
                • August 31, 1997
                • 3658
                Richard-------
                Joe is correct. AIM UPC 6, B 1
                Leif
                • Richard E.
                  • 252
                  Joe, Leif,
                  Thanks again, can't believe I overlooked it in the AIM but I found it now with your help! Yes, the bolts are knurled, appear to be factory original and the starter brace with shield is installed also.
