64 L76 AC questions - NCRS Discussion Boards
64 L76 AC questions
  • Lawrence S.
    • April 1, 1993
    • 803
    64 L76 AC questions
    Guys looking at a car, 64 L76 with AC and I am lacking on knowledge in this area of detail. Can someone let me know if this is the correct fan for this car with AC, correct compressor and pulley?
  • Leif A.
    • August 31, 1997
    • 3645
    Re: 64 L76 AC questions
    Larry,
    If you're asking if the fan and the compressor are what was on the car when it left the factory then the answer is no.
    Leif
    • Harry S.
      • July 31, 2002
      • 5331
      Lawrence. looks like a 63 compressor with a foil label added. What is the VIN of the car? Is it a very early 64 car where a 63 compressor was used and a foil label added. What is the date on the back of the compressor? The fan does look awkward.
      • Lawrence S.
        • April 1, 1993
        • 803
        Agree, the fan does look very awkward to me as well. I would think a clutch fan should be on the car? Partial VIN is 107289
        • Lawrence S.
          • April 1, 1993
          • 803
          Here is another picture of the compressor and pulley. Pulley looks correct in diameter?
            • 6950
            Agree with others fan is some sort of aftermarket, I would do some research on A/c compressor pulley Diameter and make sure it’s a deep groove pulley. I looked at the JM and the foil label looks original, compressor part number says part no.6550133/ pulley dia. Is6 3/8”
            • Lawrence S.
              • April 1, 1993
              • 803
              Seller reports that the pulley on the AC compressor is approximately 7.5" in diameter.
