Air filter does not fit on my carb - NCRS Discussion Boards
  • Twan B.
    • June 30, 2005
    • 207
    I'am building an engine for my '65 327/300 using New and old parts "all original" and my airfilter does not fot, it seems like I'am 1" short of my carb, looks like it need a 1" shim.
    Can anyone tell what I'am doing wrong?
  • Twan B.
    • June 30, 2005
    • 207
    Re: Airfilter do not fit on my carb
    Does anyone got pics of there car how it must be? 327/300
    • Owen L.
      • September 30, 1991
      • 842
      I'm unsure what you mean by it seems an inch short. Are you talking about the base or the filter element itself? And short of fitting where?
      Can you post a couple pics of the parts you have?
      • Twan B.
        • June 30, 2005
        • 207
        I don't know how to post pics :-(
        • Owen L.
          • 842
          In the reply window, click the insert photo button:
          In the next pop-up window, choose the image using the Browse button. After you select the image with Open, you will need to click Upload File(s).
          • Twan B.
            • June 30, 2005
            • 207
            This is the photo ofaircleaner.jpg my problem
            • Twan B.
              • June 30, 2005
              • 207
              Airfilter doesn't fit.
              Help wanted for my non fitting aircleaner, it does not fit on my carb, I'am building an engine for my '65 327/300 194675S104084 with new and old parts all original, when I try to put on the aircleaner it seem like I need an 1" shim.
              The crankcase vent tube is to high so my arrestor won't fit correctly.
              • John F.
                • March 23, 2008
                • 2396
                Re: Airfilter doesn't fit.
                Do you have the short hose?
                • Twan B.
                  • June 30, 2005
                  • 207
                  aircleanerhose.jpg A picture of the smal hose.
                  • Harry S.
                    • July 31, 2002
                    • 5269
                    Re: Air filter does not fit on my carb
                    Isn't there suppose to be a large plastic spacer between the carb and the intake manifold. About 3/4 inches thick. That would raise the air cleaner.
                    • Twan B.
                      • June 30, 2005
                      • 207
                      The last pic is a the insulator spacer not mounted. Now it is in place but I'am still about 1" short.
                      • Owen L.
                        • 842
                        Would you mind posting a pic of top and bottom sides of the air cleaner base and the complete top of the carburetor?
                        • Harry S.
                          • July 31, 2002
                          • 5269
                          Owen, I agree we need more information. I'm a 63 guy not 65. Looks to me like the wrong air cleaner, too thick. Manifold? Carb?
                          Think we need all he casting numbers and many more pictures.
                          • Owen L.
                            • 842
                            There was a Corvette forum thread where the photo looks just like yours (from the looks of the avatars, Harry commented then too):
                            Originally posted by SWCDuke
                            Due to a different air horn diameters for the 250 and 350/365 HP engines they had different bases and maybe different tubes, so there could have been as many as three for '65. Check you AIM. You might have the incorrect part for a 300 HP engine. I agree that the photos look like the same part, so maybe you have the wrong air cleaner base.
                            There are lots of errors in parts catalogs, both GM and aftermarket.
                            [ATTACH=CONFIG]117526[/ATTACH]
                            Here's a pic of an original on eBay. Seems the length from the bracket through the upward curve to the hose stop is much shorter than what you show on your engine.
                              • January 31, 1988
                              • 43196
                              [ATTACH=CONFIG]117533[/ATTACH]
                              Own and Twan------
                              There were 3 different tubes used over the 1964-65 period but I do not recall how they differed in configuration. The one used for this application was GM #3846110 which was discontinued in 1977. 1965 with L-76 and L-79 used a different tube.
