'56-57 Carpet - ACC or Al Knoch? - NCRS Discussion Boards
  • Bob B.
    • March 1, 2003
    • 831
    Hi All,
    Looks like 56-57 carpet is $300 for the ACC/Auto Custom Carpets and $704 at Al Knoch. I don't have either to compare, but has anyone had a car with ACC judged and had a problem?
    Bob
  • Kent S.
    • February 1, 1993
    • 203
    Re: '56-57 Carpet - ACC or Al Knoch?
    I believe the ACC carpet has the "grain" running parallel to the firewall. It should run on a diagonal (45*) from the firewall. When manufacturing the carpet there's a lot more waste when cutting it on the diagonal. You might check with AK to see how his is cut. Several years ago I replaced the carpet in my '57 with the correct grain pattern. As I recall the only company offering the correct carpet was Romeo Engineering but that may have changed.
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11318
      We used AK several years ago on a friend's '56. It wasn't diagonal grain. You best check to see if it is now. At $700 I'd hope so.
      Unsure if original, but it had diagonal grain.
      AK carpet
      Comparison grain angle, bottom is AK.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11318
        According to the AK site, it makes this comment...
        "Exact original NCRS correct Daytona weave carpet only available at Al Knoch Interiors"
        56-57-daytona-carpet-set
        A close up of their photos shows this. It appears to be at a diagonal.
        Edit- I'm thinking years ago you could get either the "replacement" or the more expensive weave. It appears they only sell the more expensive weave now.
        Rich
