Trouble with a TH400 - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1424
  • Leif A.
    • August 31, 1997
    • 3658
    Re: Trouble with a TH400
    Vacuum modulator?? Vacuum line to the modulator attached??
    Leif
      • 15644
      Leif nailed it. Check at intake manifold for vacuum line connected as well. It is also possible the vacuum modulator has failed. Check the vacuum lines and connections first.
      • Steven B.
        • June 30, 1982
        • 4018
        Yep, what they said. My TH-400 did the same and it was the modulator.
        • Michael L.
          • December 15, 2006
          • 1424
          Great thanks guys. That gives me something to check.
          • Mark E.
            • April 1, 1993
            • 4614
            Because you pulled the engine, also check the throttle and shift linkage are properly adjusted.
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
            • Michael L.
              • December 15, 2006
              • 1424
