'63 Rear Seat Mount Nut Plates - NCRS Discussion Boards
  • Douglas C.
    • September 30, 1988
    • 230
    Hi,
    Not sure if this has been addressed before, but in looking at the '63 ASM, Sect. 1, D4.00 there are no rivets to hold the outer rear seat nut plates. So in the picture below of a repro nut plate set, should the outer rivet holes be there? The part numbers are the same for the inner and outer nut plates.
    Thanks in advance for any reponses.
    --Doug Member No. 13644
  • Harry S.
    • July 31, 2002
    • 5295
    Re: '63 Rear Seat Mount Nut Plates
    Douglas, yes, the outer plate is not riveted. and yes the holes in the plater should be there.
    • Douglas C.
      • 230
      Thanks Harry!
      That's what I suspected, but I supppse its a complicating factor to repop separate inner/outer rear seat nut plates.
      I probably have the originals somewhere boxed up.
      • Harry S.
        • July 31, 2002
        • 5295
        The only reason I can come up with as to why the outboard plate was not riveted, it as cheaper. Some bean counter decided a guy on the line could reach under the body and install it as opposed to the body shop spending time riveting it in. It was the same part.
