C6, door opening touch pad - NCRS Discussion Boards
  • Harry S.
    • July 31, 2002
    • 5333
    Just curious. The tough pad to open my drivers door on my 2006 C6 now fails about 90% of the time. I ordered a GM part to replace it, for about $24.00. Part 22751230. It's a 5 minute swap.
    Question is, is this a common failure?
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11345
    Re: C6, door opening touch pad
    Harry, Yes I recall it's very common. I had both of mine on my '07 replaced under warranty in 2008. Still ok so far.
    • Harry S.
      • July 31, 2002
      • 5333
      I thought it would be a PIA to replace, but YouTube has a good video!
      This is one of those items that will help you fail a PV. I'm looking to PV the car in Marlborough next June.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11345
        Harry is yours automatic transmission?
        • Harry S.
          • July 31, 2002
          • 5333
          No, 6 speed.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11345
            Originally posted by Harry Sadlock (38513)
            No, 6 speed.
            Ok, Good. Hate to see the infamous A6 shifter cable pivot bushings fail in a PV.
            • Harry S.
              • July 31, 2002
              • 5333
              I figured that was why you were asking.
                • 15621
                Harry
                This is a very common failure, as Rich and others have mentioned. Lots about it on Corvette Forum ans cures (replacement as was pointed out, on C6 maintenance on Face Book. The U Tube v video is your friend, as you found out. I probably shouldn't speak so soon, but so far my 2008 has escaped this issue, but I have replacements on hand for when.
                • Harry S.
                  • July 31, 2002
                  • 5333
                  Harry
                  Thanks Terry. I looked at the cure, 2000 grit paper on the contacts. Seemed easy enough but some said it did not last long.
                  Cheers
                    • 15621
                    Cheers
                    I think replacement, especially at the price, is the answer, however cleaning the contacts shouldn't hurt as a easy (relatively) attempt. As I said i have no experience with this yet. At 96k miles I have no complaint yet.
                    • Harry S.
                      • July 31, 2002
                      • 5333
                      Installed the new touch pad this afternoon. A two minute swap and the problem is fixed.
