Mid Year SB Hood (65-67) - NCRS Discussion Boards
  • Kevin G.
    • February 1, 2005
    • 1076
    Can someone please help me, by explaining any differences in the small block hoods (65-67)? Pictures would really be great! My '67 has, what I'm told is a '66 hood with the emblem on the front left corner. I'd like to find an original '67, to put back on the car.
    TIA
  • Kevin G.
    • February 1, 2005
    • 1076
    Re: Mid Year SB Hood (65-67)
    I ran a search with no luck. To be more specific, were the holes used to access the bottom of the emblem studs on the 66 hood, drilled out or punched out on a 67 hood, or were the holes "embossed" but not drilled?
    • Keith B.
      • September 15, 2014
      • 1592
      65 hood frame does have emblem hole slots
      66 hood and frame has emblem holes
      67 only the hood frame has the slots like 66
      • Kevin G.
        • February 1, 2005
        • 1076
        Hi Keith, Thank for your reply! And, over there too!
        Greatly appreciated!
        • Brian M.
          • November 1, 1994
          • 128
          Kevin - this is a 66 hood.
          Brian McIntyre
          • John M.
            Infrequent User
            • August 31, 1994
            • 21
            Here's a photo of the driver side front corner of a 1967 SB hood. 1965-1967 SB hoods are identical EXCEPT for these holes. Disregard the white cord, hood is hung as wall art. A 1965 SB hood does not have these holes in the inner support frame. A 1966 SB hood has the holes in the inner support frame as well all small holes drilled in the outer skin of the hood to mount "Corvette" script emblem. A 1967 SB hood has the holes in the inner support frame but no holes in the outer skin, hence no emblem. Only a 1966 has the emblem. As you can see, a 1966 and 1967 are somewhat interchangeable, a 1965 is a one off.
            • John M.
              Infrequent User
              • August 31, 1994
              • 21
              Remove the emblem, fill the holes in the outer skin, now you have a 1967 SB hood!!
              • Kevin G.
                • February 1, 2005
                • 1076
                You guys just saved me a few bucks! My gratitude to you!
