Corvette Repair Shop Near Greenwich CT - NCRS Discussion Boards
  • Dan L.
    • May 9, 2012
    • 97
    My son lives in Greenwich CT. He has a 1966 big block and needs the carburetor repaired and probably rebuilt to NCRSD standards. Googling around we found Corvette Repair Inc out on Long Island - about three hours away. Does anyone have a trusted corvette mechanic they can recommend in the Greenwich area? Any advice is much appreciated.
    Dan Lynch
    54915
  • Harry S.
    • July 31, 2002
    • 5277
    Re: Corvette Repair Shop Near Greenwich CT
    Dan Lynch
    54915
    Dan, if it's just the carb., you do not necessarily need a shop by you. There are many carb shops in the US. I use Chris's Carb. Shop in Dayton Ohio. Chris is just finishing my 63 AFB and mailing it back this week. When Chris is done he mounts it on a 396 and runs it as a quality check.
    Other folks will chime in about their favorite carb restorers. You just need to figure out if you want a mechanical fix or a restoration (plating, etc.) and a mechanical fix. The mechanical will be just under $200. The Restoration and the mechanical will run about $450.
    Call around, pull the carb., drain it, put it in a box and ship it to whom you select. Install it when you get it back (adjust nothing), start the car and drive.
    • Dan L.
      • May 9, 2012
      • 97
      Thanks Harry - much appreciated. He would like to devewlop a relationship with a good mechanis in his area for general maintenace and repairs.
      Dan
      • Harry S.
        • July 31, 2002
        • 5277
        I understand. Might I suggest he join NCRS and the Northeast chapter based out of CT.
        • John D.
          • June 30, 1991
          • 874
          FWIW it's 35 miles from Greenwich, Ct to Valley Stream on LI.
          • Dan L.
            • May 9, 2012
            • 97
            Thanks John - what does FWIW stand for?
            • Ralph E.
              • February 1, 2002
              • 905
              "For What Its Worth"
              • Dan L.
                • May 9, 2012
                • 97
                Thanks - spoke with Kevin at Corvette Repair Inc in Valley Stream.
