69 hood latch wire suggestions - NCRS Discussion Boards
  • Richard R.
    • January 5, 2010
    • 270
    To avoid problems in the future, plus it looked a bit frayed, I replaced the wire inside the sheath of the cable that runs from the left to right hood latches. Of course, the first time I tried it out, the wire promptly snapped. causing me to have to make a tool to get that right latch free. I had installed an emergency pull cord on the left one but hadn't done the right.
    I forget what I used for replacement, perhaps picture hanging wire, but I don't want to try that again. Anyone have suggestions and where/what to get. I want to retain the original sheath if I can.
    Rich
    • 11698
    Re: 69 hood latch wire suggestions
    Did you consider buying the reproduction unit, and using your outer sheath?
      • 43288
      Patrick------
      Yes, that's the way to go IF the reproduction assembly has the multi-stranded cable (like the last available GM assembly). I would NEVER, EVER use the monofilament wire type as was originally used on most C-3's NEVER, EVER.
      • Keith M.
        • January 17, 2021
        • 695
        Patrick------
        How many originality points would one lose?
        late Oct 1969 L46 350/350, M21 4spd, 3.70 posi convertible --As with life, restoration is a journey, not a destination. Though restored cars provide both journeys AND destinations!
        • Keith M.
          • January 17, 2021
          • 695
          Rich[/QUOTE]
          Rich, do you..or anyone...have tech details and/or pics on how to make emergency pull cords?
          Keith
            • 43288
            Keith-------
            I don't know but I would not care. The original monofilament wire work hardens and breaks. That won't happen with the multi-stranded wire.
            • Richard R.
              • January 5, 2010
              • 270
              I'll take a look at a repro cable but it is probably difficult to be sure the wire on the repro will fit inside the original sheath.
              My emergency pull cord was really pretty basic - A string on the latch that extended down below the frame. For me, it was just something temporary until I am "sure" that it all works correctly and is reliable.
                • 43288
                • Richard R.
                  • January 5, 2010
                  • 270
                  OK Joe, Thanks!
